Re: Ball Joints
[Re: 6PakBee]
#3178006
09/25/23 10:00 AM
09/25/23 10:00 AM
Posts: 737 Michigan
BlueRacer69
Sorry, it's a 69 A-body, with 10 inch drum brakes.
Re: Ball Joints
[Re: BlueRacer69]
#3178073
09/25/23 01:09 PM
09/25/23 01:09 PM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
Hello. Is there a difference between upper and lower ball joints between disk brake cars and cars with drum brakes? I'm talking a 1969 car. Thanks. Uppers are the same , lower is different.
Re: Ball Joints
[Re: JohnRR]
#3178459
09/26/23 07:32 PM
09/26/23 07:32 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
Upper is the same. Lower is the same casting with 9/16" bolt holes instead of 1/2". All you need to do is drill the holes out.
That is assuming you are using the '69 ('65-72) Kelsey-Hayes disc brakes.
Re: Ball Joints
[Re: Jim_Lusk]
#3178559
09/27/23 10:30 AM
09/27/23 10:30 AM
JohnRR
U.S.S.A.
That is assuming you are using the '69 ('65-72) Kelsey-Hayes disc brakes. Good to know , thanks Jim. Also good point , if switching to the 73 up large bolt pattern discs the lower is also a different part .
Re: Ball Joints
[Re: Jim_Lusk]
#3178696
09/27/23 04:21 PM
09/27/23 04:21 PM
Posts: 737 Michigan
BlueRacer69
That is assuming you are using the '69 ('65-72) Kelsey-Hayes disc brakes. No disc, it's a 10 inch drum brake car.
Re: Ball Joints
[Re: BlueRacer69]
#3178835
09/27/23 09:02 PM
09/27/23 09:02 PM
Posts: 10,619 Freeport IL USA
poorboy
Freeport IL USA
That is assuming you are using the '69 ('65-72) Kelsey-Hayes disc brakes. No disc, it's a 10 inch drum brake car. If you plan on installing disc brakes, you will need the lower disc brake ball joints. When I installed the 73 Duster disc brakes on an older A body I used the 73 lower ball joints and the disc brake spindle. But that was a LONG time ago.
Re: Ball Joints
[Re: BlueRacer69]
#3178916
09/28/23 08:12 AM
09/28/23 08:12 AM
JohnRR
U.S.S.A.
That is assuming you are using the '69 ('65-72) Kelsey-Hayes disc brakes. No disc, it's a 10 inch drum brake car. Are you switching to discs ?
Re: Ball Joints
[Re: JohnRR]
#3179129
09/28/23 09:26 PM
09/28/23 09:26 PM
Posts: 737 Michigan
BlueRacer69
That is assuming you are using the '69 ('65-72) Kelsey-Hayes disc brakes. No disc, it's a 10 inch drum brake car. Are you switching to discs ? NO, I'm not switching to discs. This car will remain a 10" drum brake car.
