Ball Joints #3178001
09/25/23 09:50 AM
09/25/23 09:50 AM
BlueRacer69 Offline OP
Hello. Is there a difference between upper and lower ball joints between disk brake cars and cars with drum brakes? I'm talking a 1969 car. Thanks.
Re: Ball Joints [Re: BlueRacer69] #3178002
09/25/23 09:52 AM
09/25/23 09:52 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
A-body, B-body, C-body?
Re: Ball Joints [Re: 6PakBee] #3178006
09/25/23 10:00 AM
09/25/23 10:00 AM
Sorry, it's a 69 A-body, with 10 inch drum brakes.
Re: Ball Joints [Re: BlueRacer69] #3178054
09/25/23 12:39 PM
09/25/23 12:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I know the lowers are different, Uppers I believe are the same. use Rock Auto to look up the part # / application wink
Re: Ball Joints [Re: BlueRacer69] #3178073
09/25/23 01:09 PM
09/25/23 01:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Uppers are the same , lower is different.
Re: Ball Joints [Re: JohnRR] #3178459
09/26/23 07:32 PM
09/26/23 07:32 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Upper is the same. Lower is the same casting with 9/16" bolt holes instead of 1/2". All you need to do is drill the holes out.
That is assuming you are using the '69 ('65-72) Kelsey-Hayes disc brakes.
Re: Ball Joints [Re: Jim_Lusk] #3178559
09/27/23 10:30 AM
09/27/23 10:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good to know , thanks Jim.
Also good point , if switching to the 73 up large bolt pattern discs the lower is also a different part .
Re: Ball Joints [Re: Jim_Lusk] #3178696
09/27/23 04:21 PM
09/27/23 04:21 PM
No disc, it's a 10 inch drum brake car.
Re: Ball Joints [Re: BlueRacer69] #3178835
09/27/23 09:02 PM
09/27/23 09:02 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you plan on installing disc brakes, you will need the lower disc brake ball joints. When I installed the 73 Duster disc brakes on an older A body I used the 73 lower ball joints and the disc brake spindle. But that was a LONG time ago.
Re: Ball Joints [Re: BlueRacer69] #3178916
09/28/23 08:12 AM
09/28/23 08:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you switching to discs ?
Re: Ball Joints [Re: poorboy] #3178988
09/28/23 02:05 PM
09/28/23 02:05 PM
Originally Posted by poorboy
[quote=BlueRacer69][quote=Jim_Lusk]. When I installed the 73 Duster disc brakes on an older A body I used the 73 lower ball joints and the disc brake spindle. But that was a LONG time ago.
Switching to the 1973 and later front disc brake set up gets you the 4.5 inch wheel bolt pattern also up scope
I did that on my last street and strip 1971 Duster up I also swap the passenger side to the driver side and vice a versus so the heavy brake caliper were mounted behind the spindles hoping to get a little more weight moved towards the back instead of hanging on the front sides of the front spindles work scope
Re: Ball Joints [Re: JohnRR] #3179129
09/28/23 09:26 PM
09/28/23 09:26 PM
Are you switching to discs ? NO, I'm not switching to discs. This car will remain a 10" drum brake car.
