Re: mity mounts any good
[Re: willard]
#3177495
09/23/23 02:47 PM
09/23/23 02:47 PM
Posts: 15,429 Omaha Ne
TJP
Omaha Ne
Which bolts are you referring to? The cross bolts or the ones embedded in the mount itself. The only mount that really needs improving is the L one as it is the one that takes the abuse under forward acceleration. (Motor torques to the R passenger side). I have alwaays just used a 3/4 to 1 inch wide piece of strap steel off the front of the motor straight down to the k member. For 159.00 I'd send them back if possible
[Re: fastmark]
#3177659
09/24/23 06:47 AM
09/24/23 06:47 AM
Posts: 302 Ontario, Canada
GVH
Ontario, Canada
I’ve had the same problem with the mighty mounts. I believe you are 100% correct in your assessment. My biggest complaint it that the steel part that sits on the k frame does not fit properly. I have to grind on it to lay flat on the k frame on one side especially. The last one I used had the nut welded on crooked and just tacked on. The stud that bolts to the upper steel engine bracket is too long and has to be trimmed down as well. Over priced junk is what I saw. I guess the only alternative is that place that rebuilds old mounts with new rubber. Is there places that do that ? info if possible TYIA
[Re: fastmark]
#3177672
09/24/23 08:15 AM
09/24/23 08:15 AM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
I think it’s called “ then and now automotive.” I’ve seen it posted on here before. I googled it and found a website that does not work well, though. 781-335-8860. There may be other sources as well. I'll have to check this out , that area code is localish to me, I have a box of original mounts.
[Re: TJP]
#3177676
09/24/23 08:22 AM
09/24/23 08:22 AM
Posts: 106 Poland
willard
Poland
Which bolts are you referring to? The cross bolts or the ones embedded in the mount itself. The only mount that really needs improving is the L one as it is the one that takes the abuse under forward acceleration. (Motor torques to the R passenger side). I have alwaays just used a 3/4 to 1 inch wide piece of strap steel off the front of the motor straight down to the k member. For 159.00 I'd send them back if possible see pics - mity mount for driver side has 2 simple bolts screwed thru. and they screw into the steel plate on the other side of rubber. In fact the shearing strength of stock 383 is goint to rip it in 5k miles - like on my pic. this was a similar "design" used by my mechanic. it lasted 5k miles.
[Re: willard]
#3177773
09/24/23 01:12 PM
09/24/23 01:12 PM
TJP
Omaha Ne
Which bolts are you referring to? The cross bolts or the ones embedded in the mount itself. The only mount that really needs improving is the L one as it is the one that takes the abuse under forward acceleration. (Motor torques to the R passenger side). I have alwaays just used a 3/4 to 1 inch wide piece of strap steel off the front of the motor straight down to the k member. For 159.00 I'd send them back if possible see pics - mity mount for driver side has 2 simple bolts screwed thru. and they screw into the steel plate on the other side of rubber. In fact the shearing strength of stock 383 is goint to rip it in 5k miles - like on my pic. this was a similar "design" used by my mechanic. it lasted 5k miles. this is mity mount for driver side: A simple piece of strap steel tied to the K-frame will end the torn motor mount issue while being barely noticeable vibration wise. I use to hide them back in the street racing days. We were swapping motors one time trying lift the existing one out. The engine hoist kept lifting the front of the car ???? Duhhh the hidden torque strap was still in place LOL
[Re: calrobb2000]
#3178014
09/25/23 10:33 AM
09/25/23 10:33 AM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yep. I use a hardware store turnbuckle from the head to the K member. Cheap, effective, and a polished one looks good. Or they can be painted to be very inconspicuous if desired.
Master, again and still
[Re: DaveRS23]
#3178025
09/25/23 11:24 AM
09/25/23 11:24 AM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
I put bolts through the halves like the ones you got, but I put locking nuts on them, you can see the engine flex in this photo but the mount did NOT break, but I really should put a solid mount on the driver side. The Hilborn Stacks REALLY make it obvious LOL
[Re: willard]
#3178143
09/25/23 04:28 PM
09/25/23 04:28 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
[quote=willard thats some serious torque my is stock 383 auto. The manufacturer accepted refund-return so i just need to ship them overseas back to alabama [/quote] A gdzie jestes w Polsce?
[Re: 451Mopar]
#3180149
10/02/23 07:50 AM
10/02/23 07:50 AM
Posts: 28,600 Shopping @ HoBo Fright
340SIX
Doc Flappergas's Evil Twin
Haven't used those. The POLY mounts are good if you can find them, (and are expensive.)
I sort of make my own Mighty Mount, but use a single 3/8" grade 8 countersunk screw with the countersink/head on the frame side, and then drilled all the way through the engine mount bracket, with a locknut on that end. The motor mount end plates are just too thin to work as a nut. Summit Racing used to sell them
