Re: Removing dash in an 88
[Re: cudaman1969]
#3175347
09/15/23 11:37 AM
09/15/23 11:37 AM
Posts: 10,228 Colleyville
3hundred
Colleyville
Easy. there's 4 or 5 screws in the top of the dash, one just above the radio. The rest is clips, if a tilt wheel, lower it, pull carefully and it'll come right out. If you have a helper you might have them pry the top of the bezel down from the dash so it'll release easier.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: 3hundred]
#3175356
09/15/23 12:15 PM
09/15/23 12:15 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
There are a series of screws under the windshield seal...the rest is cake.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: cudaman1969]
#3175460
09/15/23 06:47 PM
09/15/23 06:47 PM
Posts: 4,588 St. John's Newfoundland
440newport
No but you really have to cut small sections out of the gasket to expose the screws, you can feel them under the rubber when you push on the gasket. It might be possible to do by prying the gasket up but I doubt it because of the angle of the screws.
[Re: cudaman1969]
#3175719
09/16/23 08:32 PM
09/16/23 08:32 PM
W.I.N. Racing
Byron, NY
I find it easier to remove the windshield...
