Air pan testing? #3175095
09/14/23 07:37 AM
09/14/23 07:37 AM
MN
JERICOGTX Offline OP
MN
Does anyone have real world, back to back, testing results of adding an air pan to seal the carb to the hood? I'm in the process of building one for my Road Runner, and wondering if it will actually pick the car up some?
69 GTX 68 Road Runner
Re: Air pan testing? [Re: JERICOGTX] #3175097
09/14/23 07:42 AM
09/14/23 07:42 AM
tboomer Online work
tboomer  Online Work
Jeff...There was a thread quite some time ago about air pans. I do believe there was results posted. Did you try a search in the race forum? up
Re: Air pan testing? [Re: tboomer] #3175099
09/14/23 07:56 AM
09/14/23 07:56 AM
MN
MN
I did. Couldn't find any results. Might have been more than 2 years ago.
Re: Air pan testing? [Re: JERICOGTX] #3175100
09/14/23 08:00 AM
09/14/23 08:00 AM
Bitopia
jcc Online content
jcc  Online Content
Bitopia
Vs nothing?
Can't imagine there is ever a downside with a air pan with a scoop as pictured.
However, depending on height available under the scoop, seems any velocity stack, even very short would-be a plus with an air pan.
I would think the biggest unknown would be what effects any wind shear across the carb might be at play regarding scoop inlet air velocity vs internal scoop volume past/downwind of the carb inlet.
edit, but with a pan that big nearly extending out over the headers, I'd be inclined to take some preventive measures to prevent generating another large heat source from radiating? more heat into inlet air.
Re: Air pan testing? [Re: JERICOGTX] #3175101
09/14/23 08:01 AM
09/14/23 08:01 AM
tboomer Online work
tboomer  Online Work
Yeah...It probably was longer than two years...
Re: Air pan testing? [Re: JERICOGTX] #3175103
09/14/23 08:02 AM
09/14/23 08:02 AM
A727Tflite Offline
A727Tflite  Offline
I consistently picked up a tenth and 1-1/2 mph on my A12 running in Stock Eliminator and SS when running the factory baseplate.
Re: Air pan testing? [Re: A727Tflite] #3175106
09/14/23 08:19 AM
09/14/23 08:19 AM
an8sec70cuda Offline
iagree I used to have a six pack hood on my cuda years ago. Sealing it to the carb was worth a tenth and 1.5 mph, but that was on a mid to low 11 sec combo. There's a lot more air flow across it at low 9 sec speed! Won't know until you try it, but I'd bet it helps.
Then this tidbit...the 5" cowl hood that's currently on the car matched the other hood's best ET and MPH...and the cowl wasn't sealed to the carb. up
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Air pan testing? [Re: A727Tflite] #3175108
09/14/23 08:21 AM
09/14/23 08:21 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We went from this unsealed scoop
To this
No change, we didn't pick up a thing. A/Fr's were the same too shruggy
Re: Air pan testing? [Re: A727Tflite] #3175109
09/14/23 08:21 AM
09/14/23 08:21 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Couple of years ago I did an A B A test. At the time I hadn't run a jetting loop so it was somewhat lean. With the pan was worth .05@2 mph.
Doug
Re: Air pan testing? [Re: Tig] #3175110
09/14/23 08:25 AM
09/14/23 08:25 AM
Tig...the lexan scoop looks better even if it isn't worth any power. twocents
CHIP
Re: Air pan testing? [Re: an8sec70cuda] #3175113
09/14/23 08:29 AM
09/14/23 08:29 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Much slower car than OP's, but open T/A Challenger scoop to sealed was a solid .1+ and 1+ MPH improvement
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Air pan testing? [Re: an8sec70cuda] #3175115
09/14/23 08:42 AM
09/14/23 08:42 AM
Mo.
racerx Offline
racerx  Offline
Mo.
x2 up
Re: Air pan testing? [Re: racerx] #3175132
09/14/23 09:23 AM
09/14/23 09:23 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
We tested my air pan setup when my current 410 c.i. small block was on the dyno a few months ago . Weather wasn’t optimum for testing and it was’ t an actual sealed to hood test . We made pulls without the setup ( open carb , no air cleaner ) and with my filter / air pan .. the results were : No loss or gain in horsepower or torque with the air pan or without . I am sure there is a gain when in the car especially in cooler air . It is good to know however that my setup isn’t hurting my performance , I like having the air cleaner especially at dusty tracks.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Air pan testing? [Re: JERICOGTX] #3175133
09/14/23 09:25 AM
09/14/23 09:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't remember the et or mph difference on my Dart with and without the air pan. It is slower with it off and the afr's are all over the place, not just at high speed but everywhere, it seems unhappy the entire run. I did A-B-A tests, and the results were the same each time. I run a belt drive fan so that may have something to do with the afr's at lower speeds.
Re: Air pan testing? [Re: justinp61] #3175137
09/14/23 09:38 AM
09/14/23 09:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
During my “oh S where’s my hoodpins” experiment there was no negligible et difference running without my hood. I do run the UNI air filter to keep out rocks.
Re: Air pan testing? [Re: J_BODY] #3175139
09/14/23 10:26 AM
09/14/23 10:26 AM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
Worth mentioning - if you search the subjects you want in google, a bunch of old Moparts and yellowbullet threads will show up, it works surprisingly well, I've found some valuable info from a decade ago that way.
I haven't sealed my scoop yet but I was surprised to see that removing my air filter completely lost 0.1 in ET and 1 mph back to back at GLD. Am definitely going to be making some type of air pan in the future.
Re: Air pan testing? [Re: Blusmbl] #3175140
09/14/23 11:04 AM
09/14/23 11:04 AM
MN
MN
I did do the google search, and came up with a thread from 2011. It was a 50/50 yes it worked, no it didn't work thread...
Re: Air pan testing? [Re: JERICOGTX] #3175142
09/14/23 11:13 AM
09/14/23 11:13 AM
PA
moparacer Offline
moparacer  Offline
PA
I have 2 cars. A 67 Barracuda, and a 70 Duster that picked up over a tenth in the 1/8 mile when we sealed the 440 6 pack scoops up to the hood.
The Barracuda was good for 1.5 tenths in the 1/4.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Air pan testing? [Re: moparacer] #3175147
09/14/23 11:41 AM
09/14/23 11:41 AM
PA
moparacer Offline
moparacer  Offline
PA
The day I tested this on our Duster it went 6.76 without, 6.66 with and 6.76 without.
Re: Air pan testing? [Re: JERICOGTX] #3175149
09/14/23 11:51 AM
09/14/23 11:51 AM
AndyF Offline
AndyF  Offline
One of the race cars that I tune is a COPO Camaro. We've run it multiple times with and without the scoop hooked up to the throttle body and the difference is 2 tenths. Runs 9 tens with the air pan, 9 thirtys without the pan.
https://youtu.be/oHcrXo0P6aY
