Air pan testing?
#3175095
09/14/23 07:37 AM
09/14/23 07:37 AM
Posts: 10,049 MN
JERICOGTX
MN
Does anyone have real world, back to back, testing results of adding an air pan to seal the carb to the hood? I'm in the process of building one for my Road Runner, and wondering if it will actually pick the car up some?
69 GTX
68 Road Runner
Re: Air pan testing?
[Re: tboomer]
#3175099
09/14/23 07:56 AM
09/14/23 07:56 AM
Posts: 10,049 MN
JERICOGTX
MN
Jeff...There was a thread quite some time ago about air pans. I do believe there was results posted. Did you try a search in the race forum? I did. Couldn't find any results. Might have been more than 2 years ago.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3175100
09/14/23 08:00 AM
09/14/23 08:00 AM
Posts: 22,731 Bitopia
jcc
Bitopia
Does anyone have real world, back to back, testing results of adding an air pan to seal the carb to the hood? I'm in the process of building one for my Road Runner, and wondering if it will actually pick the car up some? Vs nothing? Can't imagine there is ever a downside with a air pan with a scoop as pictured. However, depending on height available under the scoop, seems any velocity stack, even very short would-be a plus with an air pan. I would think the biggest unknown would be what effects any wind shear across the carb might be at play regarding scoop inlet air velocity vs internal scoop volume past/downwind of the carb inlet. edit, but with a pan that big nearly extending out over the headers, I'd be inclined to take some preventive measures to prevent generating another large heat source from radiating? more heat into inlet air.
[Re: JERICOGTX]
#3175103
09/14/23 08:02 AM
09/14/23 08:02 AM
Posts: 3,102 Michigan
A727Tflite
Jeff...There was a thread quite some time ago about air pans. I do believe there was results posted. Did you try a search in the race forum? I did. Couldn't find any results. Might have been more than 2 years ago. I consistently picked up a tenth and 1-1/2 mph on my A12 running in Stock Eliminator and SS when running the factory baseplate.
[Re: A727Tflite]
#3175106
09/14/23 08:19 AM
09/14/23 08:19 AM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Jeff...There was a thread quite some time ago about air pans. I do believe there was results posted. Did you try a search in the race forum? I did. Couldn't find any results. Might have been more than 2 years ago. I consistently picked up a tenth and 1-1/2 mph on my A12 running in Stock Eliminator and SS when running the factory baseplate. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I used to have a six pack hood on my cuda years ago. Sealing it to the carb was worth a tenth and 1.5 mph, but that was on a mid to low 11 sec combo. There's a lot more air flow across it at low 9 sec speed! Won't know until you try it, but I'd bet it helps. Then this tidbit...the 5" cowl hood that's currently on the car matched the other hood's best ET and MPH...and the cowl wasn't sealed to the carb. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: A727Tflite]
#3175108
09/14/23 08:21 AM
09/14/23 08:21 AM
Posts: 2,937 A shed in England
Tig
A shed in England
We went from this unsealed scoop ![[Linked Image]](http://i.imgur.com/YiBRZqG.jpg) To this ![[Linked Image]](http://i.imgur.com/9gqtNp5.jpg) No change, we didn't pick up a thing. A/Fr's were the same too ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3175110
09/14/23 08:25 AM
09/14/23 08:25 AM
an8sec70cuda
Tig...the lexan scoop looks better even if it isn't worth any power. ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: an8sec70cuda]
#3175113
09/14/23 08:29 AM
09/14/23 08:29 AM
Posts: 1,185 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Much slower car than OP's, but open T/A Challenger scoop to sealed was a solid .1+ and 1+ MPH improvement
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: racerx]
#3175132
09/14/23 09:23 AM
09/14/23 09:23 AM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
We tested my air pan setup when my current 410 c.i. small block was on the dyno a few months ago . Weather wasn’t optimum for testing and it was’ t an actual sealed to hood test . We made pulls without the setup ( open carb , no air cleaner ) and with my filter / air pan .. the results were : No loss or gain in horsepower or torque with the air pan or without . I am sure there is a gain when in the car especially in cooler air . It is good to know however that my setup isn’t hurting my performance , I like having the air cleaner especially at dusty tracks.
[Re: J_BODY]
#3175139
09/14/23 10:26 AM
09/14/23 10:26 AM
Posts: 8,184 Plymouth, MI
Blusmbl
Plymouth, MI
Worth mentioning - if you search the subjects you want in google, a bunch of old Moparts and yellowbullet threads will show up, it works surprisingly well, I've found some valuable info from a decade ago that way.
I haven't sealed my scoop yet but I was surprised to see that removing my air filter completely lost 0.1 in ET and 1 mph back to back at GLD. Am definitely going to be making some type of air pan in the future.
[Re: Blusmbl]
#3175140
09/14/23 11:04 AM
09/14/23 11:04 AM
Posts: 10,049 MN
JERICOGTX
MN
I did do the google search, and came up with a thread from 2011. It was a 50/50 yes it worked, no it didn't work thread...
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3175142
09/14/23 11:13 AM
09/14/23 11:13 AM
Posts: 2,527 PA
moparacer
PA
I have 2 cars. A 67 Barracuda, and a 70 Duster that picked up over a tenth in the 1/8 mile when we sealed the 440 6 pack scoops up to the hood.
The Barracuda was good for 1.5 tenths in the 1/4.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
