1968 / 1969 B Body Ignition Switches #3174785
09/12/23 07:14 PM
09/12/23 07:14 PM
Missouri
70X Offline OP
70X  Offline OP
Missouri
Is it the length of the 68 and 69 B Body ignition switches the only thing different? Can the years be interchanged if not concerned about the length?
Re: 1968 / 1969 B Body Ignition Switches [Re: 70X] #3174816
09/12/23 09:05 PM
09/12/23 09:05 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
It's the outside diameter that's different.
They will not interchange
1969 is larger and is one year only
Re: 1968 / 1969 B Body Ignition Switches [Re: gtx6970] #3174825
09/12/23 09:42 PM
09/12/23 09:42 PM
Missouri
70X Offline OP
70X  Offline OP
Missouri
Thank You!
Re: 1968 / 1969 B Body Ignition Switches [Re: gtx6970] #3174923
09/13/23 12:56 PM
09/13/23 12:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This , specifically the threaded part that goes thru the hole in the dash is a different size , you can't put a 69 switch into a 68 dash without making the hole in the dash frame , and subsequently the lower dash pad , larger. There is a difference in the wiring also , the 69 has 1 more wire than the 68 ? I've owned both years, parted a few, and played around with the switches at one point.
Re: 1968 / 1969 B Body Ignition Switches [Re: JohnRR] #3174925
09/13/23 12:59 PM
09/13/23 12:59 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Last good used 69 with key I had I got like 100 for.Guy was more than happy to get it.
Chrysler Firepower
Re: 1968 / 1969 B Body Ignition Switches [Re: therocks] #3174935
09/13/23 01:33 PM
09/13/23 01:33 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I had a 69 that quit turning. Emptied the tumblers out and it soldiered on for years. Was kinda handy to be able to stick any key or a screwdriver in it and crank it up. Locks mean basically nothing in these cars anyway, a mere hindrance of a few seconds for anybody serious about taking it.
I want my fair share
Re: 1968 / 1969 B Body Ignition Switches [Re: JohnRR] #3175050
09/13/23 09:34 PM
09/13/23 09:34 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
John,
Do you knw what the 69 thread diameter is? I have a couple a switches but am not sure what they came from. Could be 69 switches shruggy
beer
