Re: 1968 / 1969 B Body Ignition Switches
[Re: gtx6970]
#3174825
09/12/23 09:42 PM
09/12/23 09:42 PM
Posts: 154 Missouri
70X
Missouri
[Re: gtx6970]
#3174923
09/13/23 12:56 PM
09/13/23 12:56 PM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
It's the outside diameter that's different. They will not interchange
1969 is larger and is one year only This , specifically the threaded part that goes thru the hole in the dash is a different size , you can't put a 69 switch into a 68 dash without making the hole in the dash frame , and subsequently the lower dash pad , larger. There is a difference in the wiring also , the 69 has 1 more wire than the 68 ? I've owned both years, parted a few, and played around with the switches at one point.
[Re: JohnRR]
#3174925
09/13/23 12:59 PM
09/13/23 12:59 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Last good used 69 with key I had I got like 100 for.Guy was more than happy to get it.
Chrysler Firepower
[Re: therocks]
#3174935
09/13/23 01:33 PM
09/13/23 01:33 PM
Posts: 10,220 Someplace you aren't
SomeCarGuy
I had a 69 that quit turning. Emptied the tumblers out and it soldiered on for years. Was kinda handy to be able to stick any key or a screwdriver in it and crank it up. Locks mean basically nothing in these cars anyway, a mere hindrance of a few seconds for anybody serious about taking it.
I want my fair share
[Re: JohnRR]
#3175050
09/13/23 09:34 PM
09/13/23 09:34 PM
Posts: 15,438 Omaha Ne
TJP
Omaha Ne
1969 is larger and is one year only This , specifically the threaded part that goes thru the hole in the dash is a different size , you can't put a 69 switch into a 68 dash without making the hole in the dash frame , and subsequently the lower dash pad , larger. There is a difference in the wiring also , the 69 has 1 more wire than the 68 ? I've owned both years, parted a few, and played around with the switches at one point. John, Do you knw what the 69 thread diameter is? I have a couple a switches but am not sure what they came from. Could be 69 switches
