Leak free radiator hoses, what's the secret. #3174226
09/10/23 02:33 PM
09/10/23 02:33 PM
BlueRacer69 Offline OP
Okay guys, what's your secret for leak free hoses when using Corbin hose clamps. Normally I would just use a worm clamp and tighten them down good, but this car is a show car. Thanks.
Re: Leak free radiator hoses, what's the secret. [Re: BlueRacer69] #3174227
09/10/23 02:39 PM
09/10/23 02:39 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Have new hoses and clamps. Badalson has them. Put a skim coat of silicone sealant on the nozzle and slide the hose in place. Put the clamps on and let dry for at least 24 hours. Never had a leak.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Leak free radiator hoses, what's the secret. [Re: MOPARMIKE69] #3174234
09/10/23 03:19 PM
09/10/23 03:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Clamps may be wrong size or incorrect tension; BTDT many years ago.
New everything, but bottom hose leaked at radiator.
Replaced clamp with a nice used OEM and it stopped.
Did nothing else differently, had to be an error in manufacturing the repro clamp.
Re: Leak free radiator hoses, what's the secret. [Re: topside] #3174237
09/10/23 03:33 PM
09/10/23 03:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Key for the repop Corbin clamps is NOT overstretch them.
I put them on the hose.. slide the hose on the fitting clean and dry.
Open the clamp just barely enough to get it slid in place.
Spray a little wd40 will help the clamp slide.
But do not get it inside the hose.
Re: Leak free radiator hoses, what's the secret. [Re: MOPARMIKE69] #3174250
09/10/23 05:14 PM
09/10/23 05:14 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
up I also clean the inside of the hose with brake clean and skim coat it as well beer
Re: Leak free radiator hoses, what's the secret. [Re: TJP] #3174257
09/10/23 05:54 PM
09/10/23 05:54 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Man the places we use RTV Silicone
LOL
Anyways I would never think that , but
carry on
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Leak free radiator hoses, what's the secret. [Re: topside] #3174259
09/10/23 05:58 PM
09/10/23 05:58 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Wouldn’t that bee the case for a lot of repro parts today
But I agree
Siberian Huskies
Re: Leak free radiator hoses, what's the secret. [Re: BlueRacer69] #3174261
09/10/23 06:11 PM
09/10/23 06:11 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
My Ford pickup has an aftermarket overflow bottle that will not hold water. I eventually figured out that if I put any coolant in it at all, it will get pushed out through the waterpump neck.
I guess the water weight in the bottle overpressures something. The radiator is always full when cool, so I run it as is.
I've often wondered if some pesky leaks are caused by this.
Re: Leak free radiator hoses, what's the secret. [Re: A990] #3174268
09/10/23 07:44 PM
09/10/23 07:44 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Indian Head Shellac comes up as a hose sealer solution on several old car websites.
Re: Leak free radiator hoses, what's the secret. [Re: Neil] #3174292
09/10/23 09:48 PM
09/10/23 09:48 PM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
Years ago someone on here recommended weather strip adhesive . I tried it and had no leaks.
Re: Leak free radiator hoses, what's the secret. [Re: Neil] #3174293
09/10/23 09:51 PM
09/10/23 09:51 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Yes that would work, but pity the poor SOB that has to remove it unless he's replacing the hose. I believe the issue is our "QUALITY" repro clamps.
Wanted to mention using the IH on the radiator or heater core could put a few $$ in the local radiator shop's pocket wink beer
Reminds me of a friend years ago. He built his own deep sump pan and put the drain plug on the BOTTOM. ( that really didn't matter as the pan was TOO low anyway). He installed the the pan, windage tray ( 440) and gaskets with 3m's YELLOW DEATH weather-strip adhesive.
Of course the first dip in the road took out the drain plug.
I will never forget him hanging under the car with two long prybars swearing while trying to get the pan off 🤣🤣.
When he finally did after quite some time, the pan and windage tray were destroyed. He then had to get the remains off the block with scrapers and solvents. Don't think he ever used that stuff for gaskets again beer
