Indian Head Shellac comes up as a hose sealer solution on several old car websites.
Yes that would work, but pity the poor SOB that has to remove it unless he's replacing the hose. I believe the issue is our "QUALITY" repro clamps.
Wanted to mention using the IH on the radiator or heater core could put a few $$ in the local radiator shop's pocket
Reminds me of a friend years ago. He built his own deep sump pan and put the drain plug on the BOTTOM. ( that really didn't matter as the pan was TOO low anyway). He installed the the pan, windage tray ( 440) and gaskets with 3m's YELLOW DEATH weather-strip adhesive.
Of course the first dip in the road took out the drain plug.
I will never forget him hanging under the car with two long prybars swearing while trying to get the pan off 🤣🤣.
When he finally did after quite some time, the pan and windage tray were destroyed. He then had to get the remains off the block with scrapers and solvents. Don't think he ever used that stuff for gaskets again
