2 .030 venolia pistons flat top #3173467
09/06/23 09:01 PM
09/06/23 09:01 PM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
Hey guys needle in a haystack looking for 2-venolia stock compression height flat top piston's .030 Need 2 Appreciate it!
Re: 2 .030 venolia pistons flat top [Re: sean1970] #3173479
09/06/23 09:44 PM
09/06/23 09:44 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
For what engine Sean?
Alan Jones
Re: 2 .030 venolia pistons flat top [Re: LA360] #3173520
09/07/23 09:36 AM
09/07/23 09:36 AM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
440 Block .030 over Sir TY Sean
Re: 2 .030 venolia pistons flat top [Re: sean1970] #3173577
09/07/23 01:37 PM
09/07/23 01:37 PM
Have you ask them to make you two new ones? work scope twocents
Re: 2 .030 venolia pistons flat top [Re: Cab_Burge] #3173584
09/07/23 02:25 PM
09/07/23 02:25 PM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
Cab,
From what I understand they are out of business. I looked and says 2016. TY sean
Re: 2 .030 venolia pistons flat top [Re: sean1970] #3173637
09/07/23 07:56 PM
09/07/23 07:56 PM
LA360 Offline
LA360  Offline
They closed December 28th 2018 from what I have found on the internet.
Getting two done as a custom set is going to be $$$ I would imagine.
Alan Jones
Re: 2 .030 venolia pistons flat top [Re: sean1970] #3173642
09/07/23 08:19 PM
09/07/23 08:19 PM
A727Tflite Offline
A727Tflite  Offline
Originally Posted by sean1970
Cab,
Call Diamond Piston - they can likely copy your piston, would have to send one to them to be CMM’d but I bet they could provide a ballpark estimate.
Probably other piston companies would too.
Re: 2 .030 venolia pistons flat top [Re: LA360] #3173643
09/07/23 08:21 PM
09/07/23 08:21 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
.055 over were very very common back then as we liked to over bore everything back them. I’m sure some .030
Over are sitting unused on a shelf but getting word out there can be discouraging. Especially if you aren’t a Facebook user. Good luck.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
