Re: 2 .030 venolia pistons flat top
[Re: sean1970]
#3173637
09/07/23 07:56 PM
09/07/23 07:56 PM
Posts: 6,145 Melbourne , Australia
LA360
They closed December 28th 2018 from what I have found on the internet.
Getting two done as a custom set is going to be $$$ I would imagine.
Alan Jones
[Re: sean1970]
#3173642
09/07/23 08:19 PM
09/07/23 08:19 PM
Posts: 3,081 Michigan
A727Tflite
Cab,
From what I understand they are out of business. I looked and says 2016. TY sean Call Diamond Piston - they can likely copy your piston, would have to send one to them to be CMM’d but I bet they could provide a ballpark estimate. Probably other piston companies would too.
[Re: LA360]
#3173643
09/07/23 08:21 PM
09/07/23 08:21 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
.055 over were very very common back then as we liked to over bore everything back them. I’m sure some .030 Over are sitting unused on a shelf but getting word out there can be discouraging. Especially if you aren’t a Facebook user. Good luck.
