Clutch Rod Help! #317321
05/13/09 08:18 PM
05/13/09 08:18 PM
Nebraska
BLUECUDA Offline OP
super street
BLUECUDA  Offline OP
super street
Nebraska
Ok Look at the pic, and tell me if I have the right length clutch rod for a 71 Cuda 440 4-speed? It's 7 1/2in. over all, and 4 1/4in. of the shaft is threaded. The problem is the clutch wont even start to grab until the pedal is almost all the way let out. I've maxed out the adjustment on the shaft, and it got a little better but not like it should be. It's like I need more threads on the shaft to adjust the clutch. The clutch is a center force dual friction very little miles on.
Re: Clutch Rod Help! [Re: BLUECUDA] #317322
05/13/09 08:23 PM
05/13/09 08:23 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The shorter the rod the quicker the clutch release. You want about 1" freeplay at the top of the pedal.
Re: Clutch Rod Help! [Re: stumpy] #317323
05/13/09 08:37 PM
05/13/09 08:37 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
Do a little search and you'll find a lot of people(including me) have had to modify the z bar to get enough travel to fully disengage the clutch and engage it. I removed the z bar gut the lower arm and added 1/2 inch to it to make it longer. I tried a longer actuating rod but it either fully disengaged the clutch or fully allowed the clutch to engage but not both. Oh yeah I'm runnung a centerforce too.
Re: Clutch Rod Help! [Re: stumpy] #317324
05/13/09 10:37 PM
05/13/09 10:37 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
move nut other way - if i'm thinking about this properly
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
