spray paint lines
#3172999
09/04/23 11:23 PM
09/04/23 11:23 PM
Posts: 195 alabama, usa
burks340
alabama, usa
what is the best way to get spray paint lines out of a deck lid from paint in a spray can ?
Re: spray paint lines
[Re: B1MAXX]
#3173193
09/05/23 06:34 PM
09/05/23 06:34 PM
burks340
alabama, usa
this paint is hot rod black satin # 3680212 $34.00 a can through summitt . i put 4 coats on sprays in v pattern . the paint is made in germany. 12 oz can
[Re: burks340]
#3173217
09/05/23 08:27 PM
09/05/23 08:27 PM
Posts: 4,787 Star Idaho
67vertman
Star Idaho
this paint is hot rod black satin # 3680212 $34.00 a can through summitt . i put 4 coats on sprays in v pattern . the paint is made in germany. 12 oz can I painted my 70 cuda Hot Rod Satin black. I would not recommend sanding it and polishing it, without testing it on something else first!. Sanding it may remove the "tiger" stripes (that what I call the shadows) but when you polish it it will be shinny and no longer flat. My2 cents.
My Monster are real!
Living within your means makes life pretty easy.
[Re: B1MAXX]
#3173860
09/08/23 07:47 PM
09/08/23 07:47 PM
Posts: 1,002 rust belt
Moparite
rust belt
best way to get spray paint lines out Pics would be nice or an explanation of the "lines". Assuming you mean where the paint wasn't a 50% overlap and it caused "lines".
[Re: burks340]
#3174258
09/10/23 05:57 PM
09/10/23 05:57 PM
67vertman
Star Idaho
i am gonna let the paint dry for 1 month before i try to get the lines out . i am trying diferent tecniques on a duster quarter i had in loft of old bld . right now i have tried using 000 steel wool soaked in water with dish detergent after that gonna try sanding with 1500 snd paper wet sand and see what results i get. Please let us know how it turns out. When I repaint mine (Hot Rod Black) again, I bought a reverse stripe template with the 440 logo, and plan to sand it smooth and polish it.
