Page 3 of 3 1 2 3
Re: chevy hhr fan for street/strip??? [Re: hp340nos] #317255
05/14/09 02:47 PM
05/14/09 02:47 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
found it
Re: chevy hhr fan for street/strip??? [Re: hemigod426] #317256
05/14/09 02:54 PM
05/14/09 02:54 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
dont put any parts from homo hot rod=hhr, on you mopar. they are plenty of street strip universal fans too buy, try napa,auto-zone,advanced first you would be surpised to see what they have on the self
lol....thats funny stuff. You really think a cheap parts store fan is better than an OEM fan? My experience is a Good OEM fan (I run a Taurus Fan) is a million times better than any cheap generic fan.
no never said parts store fans were better, hhr fan is for 149hp motor, you would get the same cfm with parts store fan. if your going to boogy gm fans on your mopar put the good one on at least the LS1 dual fan setup is twice as good was on 305hp-33hp motors factory, local cars with turbos or juice or superchargers still dont over heat with factory dual fans and not much air flow threw cover on vette or camaro.
I'm impressed how much air the HHR fan moves. When I first turned it on it blew off all the rags I had sitting on top of the motor. I can hold a piece of paper about 4" infront of the radiator and it will suck it into the radiator. To me that's moving some serious air.
Re: chevy hhr fan for street/strip??? [Re: mcat4321] #317257
05/14/09 02:56 PM
05/14/09 02:56 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
found it
It will fit a 22" radiator perfect.
Re: chevy hhr fan for street/strip??? [Re: cudarex] #317258
05/14/09 03:00 PM
05/14/09 03:00 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
I agree, but to each their own. being that it came from a car that has 149hp doesn't mean jack. This thing is designed great and moves a bunch of air.
Re: chevy hhr fan for street/strip??? #317259
05/14/09 04:26 PM
05/14/09 04:26 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
Funny....I have one from an Aveo on my 550 hp BB
yep thats funny, drive it in traffic for 1/2 half see how good it works? i just thought he said street/strip car. would be plenty for strip car, have cheap slimline on 600hp drag car with electric pump, stock rad 190 staging-230 on return road
MOPAR OR NO CAR
Re: chevy hhr fan for street/strip??? [Re: hemigod426] #317260
05/14/09 04:51 PM
05/14/09 04:51 PM
Idaho
Runner Offline
Runner  Offline
Idaho
ive driven my roadrunner with an hhr fan through traffic for over a half hour and didnt have any issues in august. it moves a pile more air than the aftermarket fan it replaced.
it sems your dead set agaisnt them and thats ok, but dont try and discourage others from trying one when you have NO personal experiance with them. for the money its a hard fan to beat.
Post deleted by Defbob [Re: hemigod426] #317261
05/14/09 04:56 PM
05/14/09 04:56 PM
Re: chevy hhr fan for street/strip??? [Re: moparacer] #317262
05/14/09 05:00 PM
05/14/09 05:00 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
I just finished wiring up a twin 11 inch fan from jegs last night on one of their radiators. I went with twin fans so I had enough room for the water pump. They have it rated at 2700 cfm and from what I can see it does that and then some....
Best radiator and fan setup I have ever had on a car!
Can you take a pic of that setup from the top, showing how much room there is between the center of the fan setup, and the water pump? Looks like you have an electric pump. I have a mechanical. And how thick is the fan setup in the middle, where the water pump pulley would be.
I'd really appreacite it.
gary
Re: chevy hhr fan for street/strip??? #317263
05/14/09 05:07 PM
05/14/09 05:07 PM
hemigod426 Offline
hemigod426  Offline
Thanks Eric.
Just a side note: This fan works tremendously well and i'm running Twin Turbos.I can let this car run in the garage for an hour and do countless torques on the motor and it does it's job.I have the computer turn it on at 182* and turn it off at 175*.This takes at matter of a minute.
Your welcome. ...Arron...read above. Goody ran his on the street in Las Vegas heat for three years or more now. I have yet to have anyone who I've sold one to say it would not handle the job....Oh Prosports 9 second Dart had one also...driven to the track and tons of street miles.....Believe what you want but I'm afraid you are wrong on this one.
ok,ok ..ill try one if i get my drag back together this year , and pull off gm part #sticker
MOPAR OR NO CAR
Re: chevy hhr fan for street/strip??? #317264
05/15/09 10:15 PM
05/15/09 10:15 PM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
I would'nt doubt an increase Dram....the same thing happened with the Aveo fans I used to get...I do have a trick up my sleeve though
Eric Can you still get a deal on the HHR fans. I looks like a nice setup.
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: chevy hhr fan for street/strip??? [Re: hemigod426] #317265
05/15/09 11:58 PM
05/15/09 11:58 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I drive mine with a taurus fan over the Grapevine (large mountain range) in 90+ deg weather and don't get hot.
And I have driven in in 100+ weather too...runs 180-190 all day.
Re: chevy hhr fan for street/strip??? [Re: hemigod426] #317266
08/04/09 03:53 PM
08/04/09 03:53 PM
st.charles,mo.
dodgem1 Offline
dodgem1  Offline
st.charles,mo.
wrong,ya its for 149 hp,but it only runs very little and shuts down,these fans run longer on big 440,thus cooling perfectly-duuuuu!!!!!!!
Re: chevy hhr fan for street/strip??? [Re: moparacer] #317267
08/04/09 04:03 PM
08/04/09 04:03 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
is that each fan....
Mopar Performance
Page 3 of 3 1 2 3
