Nice try Hotchkis
#3170437
08/25/23 05:25 PM
08/25/23 05:25 PM
Posts: 1,111 Usa
A39Coronet
Usa
Spent more $ on the Hotchkis part vs buying ProForged and this is what I get when I open the box. Kudos to Summit for refunding the difference but we need to stop accepting this type of practice.
Re: Nice try Hotchkis
[Re: moparx]
#3170632
08/26/23 03:55 PM
08/26/23 03:55 PM
Posts: 10,713 North Dakota
6PakBee
North Dakota
Just another reason to save all the old stuff you can.
[Re: 67vertman]
#3170644
08/26/23 05:04 PM
08/26/23 05:04 PM
Posts: 20,762 A collage of whims
topside
A collage of whims
That seems dishonest to me, if it's the same exact part and not mis-packaging: are the part descriptions the same ?
A buddy of mine makes racecar tools, and sells them to Summit, Jeg's, Speedway, and others. They're all identical in materials, specification, and testing, except if the retailer wants their name etched/printed on the tool. They all sell for about the same price, like within a buck, last time I looked, but business has expanded since then. He doesn't control the retail price, though, so there could be someone marking them up more than the other guys do.
[Re: topside]
#3170651
08/26/23 05:19 PM
08/26/23 05:19 PM
Posts: 1,550 Michigan
Kiddart
this practice is commonly known and referred to as private labeling. many companies do this as a way to save money on manufacturing and sell at a high rate of return.
does the quality appear to be the same?
Thank you Kiddart
[Re: Kiddart]
#3170704
08/26/23 10:05 PM
08/26/23 10:05 PM
Posts: 1,111 Usa
A39Coronet
Usa
does the quality appear to be the same? Visually they appear to be ok, but I have nothing to compare them to. I get private label products and what not, but only if price is identical, or less. Hotchkis selling these for $20 more vs buying them from ProForged is slimy. You pick a brand because you've come to trust their quality, or their marketing, so if you can't trust they sent you genuine parts then I can't do business with you any longer. Just my $0.02.
[Re: A39Coronet]
#3171045
08/28/23 11:56 AM
08/28/23 11:56 AM
Posts: 1,704 central il.
second 70
central il.
Spent more $ on the Hotchkis part vs buying ProForged and this is what I get when I open the box. Kudos to Summit for refunding the difference but we need to stop accepting this type of practice. You might want to check with Hotchkis to make sure somebody didn't return that in the wrong box. No reason to trash them without knowing for sure. I ordered a pair of Hotchkis cuda subframe connectors from streetside and when I opened the box someone had returned their challenger connectors in the wrong box. I called Hotchkis and told them what happened and they sent the right ones that day along with a free shipping tag to return the wrong ones even though they weren't responsible for the mistake.
[Re: parksr5]
#3171052
08/28/23 12:15 PM
08/28/23 12:15 PM
Posts: 10,205 Someplace you aren't
SomeCarGuy
The other possibility that I've seen a lot lately, people buy both, switch the parts in the boxes and return the cheaper, lesser part in the more expensive box. I’ve had a variation of this when buying from Amazon. I’ve received things that were clearly opened and one piece taken out. If the retailer doesn’t check the return, they will send it right back out the way it came in. I’ve noticed Costco getting more picky about looking in boxes the last couple years where before returns were simply scanned and set behind the counter.
I want my fair share
[Re: migsBIG]
#3171135
08/28/23 05:08 PM
08/28/23 05:08 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
I always ask myself if a vendor is capable of making said part or capable of designing something and having it made exclusively for them.
68 Barracuda Formula S 340
[Re: SomeCarGuy]
#3171163
08/28/23 06:05 PM
08/28/23 06:05 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
The other possibility that I've seen a lot lately, people buy both, switch the parts in the boxes and return the cheaper, lesser part in the more expensive box. I’ve had a variation of this when buying from Amazon. I’ve received things that were clearly opened and one piece taken out. If the retailer doesn’t check the return, they will send it right back out the way it came in. I’ve noticed Costco getting more picky about looking in boxes the last couple years where before returns were simply scanned and set behind the counter. Menards and Home Depot come to mind
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Powerflow]
#3171286
08/29/23 10:22 AM
08/29/23 10:22 AM
Posts: 4,769 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Recently on FB Dakota page a member proudly showed his new upper ball joints installed. Said he used an electric impact gun from Harbor Freight to remove/unthread the upper ball joints. He said now he can return the impact for a refund. I asked him why return it as he will have more use for it in the future. He said he only needed it for the Ball Joint job and wanted his money back. When I bought my small Vulcan mig welder from HF the employee said "Please don't use it for your project then return it." People are frivolous cheap fools.
Keep old mopars alive.
[Re: parksr5]
#3171337
08/29/23 12:50 PM
08/29/23 12:50 PM
Posts: 7,367 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Worse one I've seen; my Father in Law is changing his oil, the new oil came from Wal-Mart. He opens the oil and realizes that someone put their old oil in the containers and returned them. I do this on every oil change. I put the old oil in the original container and return it to Wal-Mart. Wal-Mart takes your old oil for disposal for free. They just limit you to 3 gallons per day. I can easily see how someone could see a new looking container sitting on the floor by the desk and returned it to the shelf without checking it. That's on Wal-Mart...not someone returning used oil for a refund.
