Re: Will These Rear Wheel/Tires Fit ? Challenger
[Re: JFChallenger440]
#3170075
08/24/23 09:20 AM
08/24/23 09:20 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Not gonna fit without and
[Re: an8sec70cuda]
#3170103
08/24/23 10:30 AM
08/24/23 10:30 AM
Posts: 4,779 Holland MI Ottawa
2boltmain
Holland MI Ottawa
All thru the 70s and 80s many of us ran N50x15 tires on 15x10 wheels on E bodies. The N 50 is about 28"tall and 12.6" at the sidewall. A 15x10 wheel with 4.5 backspace provided clearance on the inside but air shocks were mandatory to keep the rear up high and not coming down onto the outer tread of the tire. So even an N50 did not fit correctly and it is smaller in diameter than the tire you are inquiring about. 6.5" backspace is a huge no go on the wheels.
Keep old mopars alive.
[Re: Sniper]
#3170143
08/24/23 01:52 PM
08/24/23 01:52 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
5-1/2" back space would fit +/- some for each individual car/factory tolerances. I run 315/60/15 drag radials (30") tall with no wheel well modifications.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
#3170174
08/24/23 03:50 PM
08/24/23 03:50 PM
6PKRTSE
Motor City
Mine however is mini tubbed with 12" wide wheels with 6" b.s. I was just clarifying that a 30" dia tire with fit.
#3170313
08/25/23 10:09 AM
08/25/23 10:09 AM
Posts: 2,924 A shed in England
Tig
A shed in England
With the springs in the stock location they won't fit. I use a b body width axle with the front spring box moved to the frame rail and 2" staggered hangers. Wheels are 10" wide with 5" b/s. With a 10.5 x 29.5 radial slick I have 1/2" min clearance from the springs. They are also close to the wheel opening lip too. Unfortunately I don't have any decent photo's of the fitment.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3170321
08/25/23 10:43 AM
08/25/23 10:43 AM
2boltmain
Holland MI Ottawa
While I offer no concrete proof - IIRC a 275 60 15 on a 15x8 wheel with 4.5" BS is the largest that fit properly in a STOCK wheel well application. I have a 95 Dakota project currently. I bought my tires. 29 15 15 Hoosier radials. I bought a kind of pricey tool that simulates any wheel for proper fitment and correct wheel purchase.
https://www.speedwaymotors.com/Wheel-Fitment-Tool-for-Tire-Fit-Testing-Size-Measuring-Mockup,485869.html?utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=CjwKCAjwoqGnBhAcEiwAwK-OkbJzMGWZQCERpoljGSqCxLGyL2KdqnNirEvhHZPPuEy0wNpKZ3KniRoCslgQAvD_BwE
#3171089
08/28/23 02:11 PM
08/28/23 02:11 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
IF your leafs are still in stock locations, the tires will likely hit the leafs a little, a 1/4" spacer could help relieve that interference. Also, plan to flush your fender lips as however needed.... not any big deal if the car already has some mods. Those are tall tires.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
