Will These Rear Wheel/Tires Fit ? Challenger #3169926
08/23/23 03:20 PM
08/23/23 03:20 PM
London, England
JFChallenger440 Offline OP
London, England
I have my doubts but thought I’d ask anyway on some wheels/tires I’ve seen for sale
74 Challenger
Fairly stock height at the rear
Not tubbed
Would these fit ? ….
15 x 10 Weld Pro Stars
6”’backspace
Micky Thompson 30 x 12.5
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: JFChallenger440] #3169942
08/23/23 04:10 PM
08/23/23 04:10 PM
moparx Offline
moparx  Offline
my gut tells me the 6" back space will hit the springs, and the 30" height will hit the front of the wheel opening at the very bottom.
hopefully, others will chime in with personal experience.
beer
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: JFChallenger440] #3170075
08/24/23 09:20 AM
08/24/23 09:20 AM
an8sec70cuda Offline
Not gonna fit without sawzall and wrench
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: an8sec70cuda] #3170103
08/24/23 10:30 AM
08/24/23 10:30 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
All thru the 70s and 80s many of us ran N50x15 tires on 15x10 wheels on E bodies. The N 50 is about 28"tall and 12.6" at the sidewall. A 15x10 wheel with 4.5 backspace provided clearance on the inside but air shocks were mandatory to keep the rear up high and not coming down onto the outer tread of the tire. So even an N50 did not fit correctly and it is smaller in diameter than the tire you are inquiring about. 6.5" backspace is a huge no go on the wheels.
Keep old mopars alive.
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: 2boltmain] #3170111
08/24/23 11:04 AM
08/24/23 11:04 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Conversely, and somewhat irrelevantly, Pro Trac N50-15's fit just fine in the back of my 64 300 running Cragar SS 15x10's. No Skyjackers needed.
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: Sniper] #3170143
08/24/23 01:52 PM
08/24/23 01:52 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
5-1/2" back space would fit +/- some for each individual car/factory tolerances. I run 315/60/15 drag radials (30") tall with no wheel well modifications.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: 6PKRTSE] #3170153
08/24/23 02:18 PM
08/24/23 02:18 PM
London, England
London, England
Nice , any more pics ? Thanks
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: JFChallenger440] #3170174
08/24/23 03:50 PM
08/24/23 03:50 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Mine however is mini tubbed with 12" wide wheels with 6" b.s. I was just clarifying that a 30" dia tire with fit.
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: JFChallenger440] #3170313
08/25/23 10:09 AM
08/25/23 10:09 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
With the springs in the stock location they won't fit. I use a b body width axle with the front spring box moved to the frame rail and 2" staggered hangers. Wheels are 10" wide with 5" b/s. With a 10.5 x 29.5 radial slick I have 1/2" min clearance from the springs. They are also close to the wheel opening lip too. Unfortunately I don't have any decent photo's of the fitment.
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: Tig] #3170321
08/25/23 10:43 AM
08/25/23 10:43 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
While I offer no concrete proof - IIRC a 275 60 15 on a 15x8 wheel with 4.5" BS is the largest that fit properly in a STOCK wheel well application. I have a 95 Dakota project currently. I bought my tires. 29 15 15 Hoosier radials. I bought a kind of pricey tool that simulates any wheel for proper fitment and correct wheel purchase.
https://www.speedwaymotors.com/Wheel-Fitment-Tool-for-Tire-Fit-Testing-Size-Measuring-Mockup,485869.html?utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=CjwKCAjwoqGnBhAcEiwAwK-OkbJzMGWZQCERpoljGSqCxLGyL2KdqnNirEvhHZPPuEy0wNpKZ3KniRoCslgQAvD_BwE
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: 2boltmain] #3170451
08/25/23 06:40 PM
08/25/23 06:40 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
The issue is not the size of the wheel wells, but the spring location. E body springs are splayed wider at the back, so without a spring relocation, you will hit these before you run into the wheel well.
With a 1.5-2" spring relocation, you can fit a 335 width tire in the stock Challenger well.
I have fit a 295/50 on a 15x8 wit 5.25 backspace in my Challenger with no mods at all.
My Current set up is a 305/45 on a 15x10 with 5" back space and a 2" spring relocation and a B body housing. The 2" relocation makes the B body housing a drop in with no perch relocation. If you retain the stock E body housing you will need to move the perches to mate with the spring relocation and you could get away with a 6" back space.
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: TC@HP2] #3171051
08/28/23 12:10 PM
08/28/23 12:10 PM
London, England
London, England
What tire size would fit with a 15 x 10 and that 6” backspace ? Thanks
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: JFChallenger440] #3171065
08/28/23 12:55 PM
08/28/23 12:55 PM
moparx Offline
moparx  Offline
the 6" backspace wheel will hit the springs, without the tire. i'm almost positive of that.
beer
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: moparx] #3171087
08/28/23 02:07 PM
08/28/23 02:07 PM
London, England
London, England
Ok thanks , makes you wonder why they make the wheel with that backspace ? I guess for people with modded drag cars ?
Re: Will These Rear Wheel/Tires Fit ? Challenger [Re: JFChallenger440] #3171089
08/28/23 02:11 PM
08/28/23 02:11 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
IF your leafs are still in stock locations, the tires will likely hit the leafs a little, a 1/4" spacer could help relieve that interference. Also, plan to flush your fender lips as however needed.... not any big deal if the car already has some mods. Those are tall tires.
