Re: Looking at trailers - so many options and choices
[Re: crackedback]
#3165668
08/04/23 10:23 PM
08/04/23 10:23 PM
Posts: 4,806 Moved to N.E. Tennessee
GomangoCuda
When Looking at used trailers make sure you closely inspect the tires or just assume they will need to be replaced. Check dates, sidewall cracks, weight ratings. Also be aware that a lot of used trailers wind up with car or truck tires on them which is very much against DOT regulations. Some years ago Pennsylvania DOT was actively pulling over car hauling trailers and handing out tickets for incorrect tire type and/or weight rating. Probably worse now. IIRC, the use of truck tires is OK, they are weight de-rated for use on a trailer. Sorry I over simplified that. The manufacturer of the trailer can choose to use either ST or LT tires. The catch is that if the trailer was rated with ST tires then LT tires of the same size most likely don't have as high of weight rating as the ST tires that were rated for the trailer. If you use tires with a lower weight rating than what came on the trailer then that can cause problems with insurance, warranty, and yes DOT. So if your trailer came with LT tires then you certainly can use LTs and probably STs because they would have a higher rating but if it came with STs then LTs will probably have too low of weight rating. So technically it's not the LT designation that can be a problem it is the lower weight rating of the LT.
[Re: jcc]
#3165882
08/06/23 12:22 AM
08/06/23 12:22 AM
Posts: 10,293 Someplace you aren't
SomeCarGuy
I personally am very skeptical of the alleged real uniqueness of trailer rated tires, other than its a legal escape clause for manufacturer liability. Weight limits and size are of course another matter. Semi's often have all position tires used, steering, drive and trailer. I don’t know why you’d doubt an ST tire is a specific build. Sidewall flex is the issue and thise are stiffer. You don’t run them on a truck because they’d beat you to death. Running an LT tire on a trailer reduces the load rating by 11%. Due to sidewall flex they run hotter and hence the derating. I dunno if you’d get a ticket for it or not, but I’ve seen them on trailers for years and years.
I want my fair share
[Re: SomeCarGuy]
#3165887
08/06/23 06:55 AM
08/06/23 06:55 AM
Posts: 23,268 Here
jcc
Here
Well, it's not a problem with semi's. Any potential issues with sidewall flex will be on a multi axle trailer and at under 5 mph.
" All sorts of things can happen when you are open to new Ideas" Inventor of Kevlar
[Re: gtx6970]
#3168051
08/15/23 11:19 AM
08/15/23 11:19 AM
Posts: 3,472 Newburgh, NY
Old_Moparz
Newburgh, NY
The trailer I have is made by "Load Trail" that I bought new in 2003. It's been a good trailer & it tows great. It's a 16' with a 7000 pound capacity, double axle with brakes on both of them, built in ramp storage, front curb rail & a wood deck. I had a local shop add D rings in several areas to give me better anchoring points. I also needed to replace a lot of the deck boards 5 years ago because I have to park it outdoors. I scuffed up the paint, cleaned some scale off the frame & repainted it with rattle cans a few years ago.
an 18' trailer would be ideal but the 16' is adequate, even for a B-Body.
Not sure where you are located but I got it from Marshall's Machinery in the Scranton, PA area for $1750 back when used ones were going for $2000 to $2500.
[Re: Cab_Burge]
#3169795
08/22/23 09:04 PM
08/22/23 09:04 PM
Posts: 21,758 It's a dry heat
gtx6970
It's a dry heat
Update, And giving some thoughts to look at an enclosed, most likely a clean used one.
Taking any potential resale values out of it,
Why not a 20 footer ? The car will fit just fine. And have no real interest in extra storage gains. And I can find several avail in that size
Any issues strapping a car down in this size trailer ? Any brands to avoid put to the top of the list in regards to quality?
Seems all the ones Im seeing are 10,000 gvw so a 24' will haul less than a comparatively equipped 20'
Like I said, odds are pretty good I will only keep it maybe 2 years. And dont want to take a bath on one at resale time.
As an example https://www.facebook.com/marketplace/item/1963259404041348/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A4a4e930d-47d5-4ee8-b031-7e082b2fb5a4
another one
https://www.facebook.com/marketplace/item/1716139145878442/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A4a4e930d-47d5-4ee8-b031-7e082b2fb5a4
[Re: topside]
#3169849
08/23/23 08:11 AM
08/23/23 08:11 AM
Posts: 5,025 new jersey usa
11secdart
new jersey usa
My 20 ft ... its a little tight because I carry a lot of stuff.. scooter, generator, but I make it work . I recently added a winch which takes up even more room and its a challenge using it while the scooter is in the trailer but again I make it work. I recommend getting a winch it comes in so handy .. just this past weekend broke a u joint and hurt the driveshaft I sure was I glad had a winch as loading the car afterwards was very easy.
[Re: J_BODY]
#3169861
08/23/23 09:47 AM
08/23/23 09:47 AM
Posts: 23,268 Here
jcc
Here
Tire enemies in descending order IMO: 1. Low/improper pressure 2. Overweight 3. High speed 4. Lack of regular use 5. Direct Sun exposure UV 6. High road temp 7. High Ambiant temps
[Re: gtx6970]
#3169981
08/23/23 07:54 PM
08/23/23 07:54 PM
gtx6970
It's a dry heat
Also giving some thoughts to one of these.
My fear is the steel decks get slick when wet! So, I wonder if the car will move around in transport,,,,OR make it difficult to load / unload in wet conditions
https://www.facebook.com/marketplace/item/253765690782008/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A0afd0f9f-5ab5-453f-8a0c-d25d24e40233
[Re: jcc]
#3170037
08/24/23 01:11 AM
08/24/23 01:11 AM
SomeCarGuy
Well, it's not a problem with semi's. Any potential issues with sidewall flex will be on a multi axle trailer and at under 5 mph. What are you even talking about? You didn’t know what the deal was with an ST tire. I gave you the facts.
[Re: gtx6970]
#3170038
08/24/23 01:16 AM
08/24/23 01:16 AM
SomeCarGuy
I always thought those looked cool. The step would be useful, but I also always considered the extra weight to drag around. If you can live with your car being exposed, an open is a breeze to deal with(no pun intended.). If you go enclosed, get one with a winch or plan to add one. All the enclosed ones I was involved with made life better by winching in. The ones without were super unfun. For the money and used ones needing tires and/or brakes, plus the high resale on used trillers, I’d seriously consider buying a new one.
[Re: SomeCarGuy]
#3170040
08/24/23 01:47 AM
08/24/23 01:47 AM
Posts: 23,268 Here
jcc
Here
[I personally am very skeptical of the alleged real uniqueness of trailer rated tires, other than its a legal escape clause for manufacturer liability. Weight limits and size are of course another matter. Semi's often have all position tires used, steering, drive and trailer.
quote=SomeCarGuy] Well, it's not a problem with semi's. Any potential issues with sidewall flex will be on a multi axle trailer and at under 5 mph. What are you even talking about? You didn’t know what the deal was with an ST tire. I gave you the facts. [/quote]I don't see any need to repeat myself. Maybe if you were more specific in expressing your confusion, I might be able to clarify. Tell me, what is the deal with an ST tire with facts rather than claims. Are you saying with the same size tire with same load rating category a LT is rated significantly different than a ST? Even if so, the marked load rating chosen should match or exceed the application, period. BTW, tire sidewall flex on a trailer tire is only extreme when doing tight turns on tandem+ axle trailers which is usually at the low speeds speaking of "facts". Normal sidewall flex is of no greater concern on a trailer vs any other vehicles under normal driving conditions that I haven't already noted above and requiring no special consideration for sidewall stiffness., but if you got facts to prove otherwise, I'm all ears. I believe I debunked your stiffness concern by noting semis's have and use often all position tires and your noted stiffness seems to be of little concern it appears with all position rated tires..
[Re: jcc]
#3170056
08/24/23 07:54 AM
08/24/23 07:54 AM
SomeCarGuy
Once again jcc pollutes the board with his engineering degree, rock star music ability, and Ivy League tv lawyer Superman skills. It was bliss not having him on the board for awhile, too bad he’s back.
All because jcc doesn’t know squat about trailer tires. Good luck proving what you are alleging. I posted the deal with ST because you showed up here not knowing what they are and what they are for. That’s not a me problem, it’s a jcc problem. Deal with it.
