70 rt/se challenger with custom rivets #3168786
08/18/23 12:24 PM
08/18/23 12:24 PM
Someplace you aren't
SomeCarGuy Offline OP
https://www.ebay.com/itm/235137221621?
They don’t know why it has a salvage title? I have some ideas.
I want my fair share
Re: 70 rt/se challenger with custom rivets [Re: SomeCarGuy] #3168793
08/18/23 12:42 PM
08/18/23 12:42 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Rivets could simply be due to a dash pad change. And just means a buyer does there due diligence on in person inspection. ( should do that any way IMO )
Hell,,,, a salvage title could be simply a theft recovery ( I now for a fact thats possible
But for me that is about as near a perfect E body as they could make.,,,almost. And if legit isnt priced out of line for the colors and options combo. The title status wouldn't stop me at all.
Re: 70 rt/se challenger with custom rivets [Re: gtx6970] #3168794
08/18/23 12:52 PM
08/18/23 12:52 PM
I’m assuming it’s a “rebuilt” title and if so you could legally drive it, which I would do aggressively and often. It’s a really nice combo and the formal roof e bodies are the only vinyl top cars I like.
I just found it intriguing that somebody felt the need to hand make those rivets instead of buying some or even just leaving them alone. Looks shady to go at it this way IMO.
Re: 70 rt/se challenger with custom rivets [Re: SomeCarGuy] #3168806
08/18/23 01:38 PM
08/18/23 01:38 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
20-25 years ago. or maybe sooner you couldn't find the correct rivets. So you make do with what you have at the time.
Like mentioned, I would just look a little closer if I was a buyer ,,,,and I am not.
Re: 70 rt/se challenger with custom rivets [Re: gtx6970] #3168812
08/18/23 01:51 PM
08/18/23 01:51 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Nice Challenger. I like it a lot. I don't see M91-luggage rack on the fender tag. I'm assuming that the rack was added.
Re: 70 rt/se challenger with custom rivets [Re: gtx6970] #3168817
08/18/23 02:05 PM
08/18/23 02:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ah, Kassabian's - been around for a long time, wonder why the name change ?
Looks like a decent driver car, with a few curiosities:
orange showing through hood latch support
zolotone trunk
rear speaker switch
pounded oil pan
VIN rivets - hopefully a dash pad change some time ago
Salvage title could be from a lot of things, of course: theft recovery, wreck, flood...requires a careful inspection & detective work.
Re: 70 rt/se challenger with custom rivets [Re: 318 Stroker] #3168828
08/18/23 02:14 PM
08/18/23 02:14 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
IMO a much better option to add versus the wing.
Re: 70 rt/se challenger with custom rivets [Re: gtx6970] #3168845
08/18/23 03:15 PM
08/18/23 03:15 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I've always had a soft spot for racks on an E-body. Back in the day I put one on my 73 Challenger. I still have the car. However, after restoring it, I opted for a 71 wing, which I like also.
Re: 70 rt/se challenger with custom rivets [Re: 318 Stroker] #3168884
08/18/23 05:02 PM
08/18/23 05:02 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Nice Challenger.
The auction was ended by seller, so the salvage title might have checked out good.
Re: 70 rt/se challenger with custom rivets [Re: A990] #3168889
08/18/23 05:23 PM
08/18/23 05:23 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
Missing the SE rocker trim.
No pics of trunk pan w/o the mat on.
Duh.
Nice rig, but woulda been cooler w/PW and a four-speed for $70k.
Re: 70 rt/se challenger with custom rivets [Re: 2fast4yourBrain] #3168946
08/18/23 11:13 PM
08/18/23 11:13 PM
I too think the rack is the way to go on e bodies. The trunk is pretty weak at this price point.
Re: 70 rt/se challenger with custom rivets [Re: 2fast4yourBrain] #3168955
08/19/23 02:07 AM
08/19/23 02:07 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
M25 was not STANDARD on the SE
Re: 70 rt/se challenger with custom rivets [Re: 318 Stroker] #3169003
08/19/23 11:54 AM
08/19/23 11:54 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Kassabian Motors, haven’t thought of them in quite some time. Bring back memories up
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: 70 rt/se challenger with custom rivets [Re: A990] #3169068
08/19/23 06:16 PM
08/19/23 06:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Originally Posted by A990
Nice Challenger.
Back up
https://www.ebay.com/itm/235139367934?
Re: 70 rt/se challenger with custom rivets [Re: gtx6970] #3169115
08/19/23 10:29 PM
08/19/23 10:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I wonder what's up with all the missing engine, trans and trunks paint? Somebody a little to aggressive with a Hotsy or the wash down after a salt bath? Appears to be a fresh bomb can job on the bottom side.
A 4 spd would've had me drool
Definitely would have to do some history checking. The title issue wouldn't scare me but the salt bath would. Current owner's had it for 10 years? OK, where did he get it from? are the body stampings present? whistling twocents
Anyone notice the black speedo needle??? tach seems a bit faded as well shruggy
Re: 70 rt/se challenger with custom rivets [Re: TJP] #3169123
08/20/23 12:46 AM
08/20/23 12:46 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
it's a broken speed-o needle scope
Re: 70 rt/se challenger with custom rivets [Re: 6bblgt] #3169124
08/20/23 12:47 AM
08/20/23 12:47 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
whistling 245/60/15s on the front & 235/60/15s on the rear fan
Re: 70 rt/se challenger with custom rivets [Re: 6bblgt] #3169125
08/20/23 01:03 AM
08/20/23 01:03 AM
AC should work to pull the big bucks. No mention of it and I get a bad feeling when looking at the parts.
Re: 70 rt/se challenger with custom rivets [Re: SomeCarGuy] #3169150
08/20/23 08:49 AM
08/20/23 08:49 AM
Puttin' on the foil in Charles...
not_a_charger Online mad
Mr. Big Shot Moparts Moderator
not_a_charger  Online Mad
Nothing screams muscle car like a luggage rack. puke
Earning every penny of that moderator paycheck.
DBAP
Re: 70 rt/se challenger with custom rivets [Re: gtx6970] #3169202
08/20/23 01:28 PM
08/20/23 01:28 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I agree. Somehow they just look right to me, and the wing doesn't.
Facts are stubborn things.
