Re: What size valve stem to use with rallye wheels?
[Re: vinnyd76]
#3168335
08/16/23 04:50 PM
08/16/23 04:50 PM
Posts: 21,507 N.E. OHIO, USA
A12
N.E. OHIO, USA
These are not the correct length but this is what I would use if you can with a trim ring? The TR412 short valve stems. The originals are I think a half inch longer or there abouts and you may (probably) have to use the longer valve stems.
[Re: A12]
#3168342
08/16/23 05:43 PM
08/16/23 05:43 PM
Posts: 20,763 A collage of whims
topside
A collage of whims
Rallyes with trim rings used extensions on regular valve stems, so you can get an air chuck on them. Seems to need 1.25" total height according to some guys, 1.50" according to others. IIRC, the extensions had white centers, but whether dead-correct ones are available, I don't know. If it doesn't have to look stock, and the trim rings move around, that could be an issue unless the stem have a steel jacket. It's been a LONG time since I had trim rings on anything, but I remember Dad's '66 Sport Fury's wheel covers would rotate and cut into the valve stems.
[Re: topside]
#3168356
08/16/23 07:17 PM
08/16/23 07:17 PM
Posts: 6,241 nowhere
Sniper
nowhere
Rallyes with trim rings used extensions on regular valve stems, so you can get an air chuck on them. Seems to need 1.25" total height according to some guys, 1.50" according to others. IIRC, the extensions had white centers, but whether dead-correct ones are available, I don't know. If it doesn't have to look stock, and the trim rings move around, that could be an issue unless the stem have a steel jacket. It's been a LONG time since I had trim rings on anything, but I remember Dad's '66 Sport Fury's wheel covers would rotate and cut into the valve stems. The stock hubcaps on my 51 Plymouth does this. Chrysler made chrome valve stem covers to fix that, still available. No idea if they'd work on a trim ring though https://www.oldmoparts.com/parts/e_wheels/chrome-valve-stem-cover/Me? I just cut a length of fuel hose and slipped it over the stem.
