2008 3.5L Chrysler Sebring Engine Code Issue
#3167540
08/12/23 09:19 PM
08/12/23 09:19 PM
Posts: 555 Berlin, CT
SportFuryS/23383
Confused
Confused
Berlin, CT
Hi Everybody, It's been quite awhile since I posted here last and I'm sorry, but I'm trying to help out my stepdad. He recently bought a 2008 Chrysler Sebring with a 3.5 liter with only 118,000 miles on it, however it has a problem with throwing an engine code for a cam position sensor. It starts up with the code off but when we start driving it, the code comes back on. A new sensor was in it when we got it, then we put another new one in it and its still on. Any ideas of what it could be? Any help is appreciated, thanks in advance
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: 2008 3.5L Chrysler Sebring Engine Code Issue
[Re: Wicked49670dart]
#3169414
08/21/23 12:43 PM
08/21/23 12:43 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
That 3.5 uses a timing belt, do you know the last time the belt was replaced? I don’t think ever, but we took it off and we got that and other parts on the way
[Re: SportFuryS/23383]
#3169537
08/21/23 08:35 PM
08/21/23 08:35 PM
Posts: 4,954 WI
Dcuda69
WI
That 3.5 uses a timing belt, do you know the last time the belt was replaced? I don’t think ever, but we took it off and we got that and other parts on the way I've had a couple of those 3.5s. Great little engines but yep...they need a belt at 100k. I lost one belt at 102k...lol. Look close at the water pump and the tensioner while you're in there. Get it up and running...if it still sets a code please tell us which exact code.....saying it "throws a code for the cam sensor" isn't helpful as there are likely multiple codes dealing with cam sensor(s).
[Re: Dcuda69]
#3169695
08/22/23 02:12 PM
08/22/23 02:12 PM
Posts: 19,480 north of coder
moparx
i did the belt, water pump, and tensioners in my wife's concorde with a 3.5 at 104k [and change] i was surprised to find the original belt "looked" fine, but one of the tensioners [the only one ? i really forget] was starting to get a roughness in the bearing. i think i got it just in time. and for whatever it's worth, this car was a long trip, maintenance done as required, not beat on, vehicle.
[Re: SALEM1912]
#3171442
08/29/23 06:18 PM
08/29/23 06:18 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Well,
The timing belt, tensioner, pulley and water pump were replaced BUT unfortunately the light is still on. It does have a code called “cam position sensor intermittent” if that helps any. However we’re thinking it maybe an electrical issue……. Any ideas?
#3171478
08/29/23 08:28 PM
08/29/23 08:28 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Well,
The timing belt, tensioner, pulley and water pump were replaced BUT unfortunately the light is still on. It does have a code called “cam position sensor intermittent” if that helps any. However we’re thinking it maybe an electrical issue……. Any ideas? What are the P codes?
[Re: NITROUSN]
#3172120
09/01/23 04:18 PM
09/01/23 04:18 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
This is the code it throws in my picture here. My stepdad replaced the crank sensor today and the light still comes on too
#3172122
09/01/23 04:26 PM
09/01/23 04:26 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Crank sensor box and part number……..
#3172124
09/01/23 04:40 PM
09/01/23 04:40 PM
SportFuryS/23383
Confused
Confused
Berlin, CT
Not sure if I mentioned it, but the cam sensor was also replaced……
#3172153
09/01/23 06:55 PM
09/01/23 06:55 PM
Posts: 742 Oak Harbor, WA
Wicked49670dart
Oak Harbor, WA
Did you try to resync the cam and crank sensor using a scan tool? I would also check the camshaft tone ring for issues as well, next step would be to verify the wiring from the camshaft sensor and the crankshaft sensor to the pcm wiggling the wiring harness while watching your omh meter.
