Another Street Hemi Carb #3163494
07/26/23 07:43 PM
07/26/23 07:43 PM
A727Tflite Offline OP
WIW.
Nice shape, only missing the idle mixture screws but I think I have a set that would go with carb.
0A218E6E-4AD8-4EF1-9EF4-37A1C5BF0511.jpeg4B5BE640-787F-4D6F-AD7B-476BC6FB41D9.jpeg1D93AC78-D27A-4FF2-AAAD-341BF5FBD143.jpeg
Re: Another Street Hemi Carb [Re: A727Tflite] #3166800
08/09/23 12:48 PM
08/09/23 12:48 PM
VA
dragon slayer Offline
VA
It is out of the production window, over counter date code for a 67 hemi. Missing the choke which is an expensive part to replace as original. Even repo is expensive. So from my perspective a parts carb if someone needs good parts to repair a production line carb. But others may want it as is. 66-67 and even 68 are in less demand than the later carbs.
Re: Another Street Hemi Carb [Re: dragon slayer] #3166906
08/09/23 07:34 PM
08/09/23 07:34 PM
I may have a choke for it. This carb was on my 71 Hemi GTX when I bought it, hence no need for the choke mechanism.
Re: Another Street Hemi Carb [Re: A727Tflite] #3167178
08/10/23 09:40 PM
08/10/23 09:40 PM
VA
VA
71 used a manual choke device for cable operation.
Re: Another Street Hemi Carb [Re: dragon slayer] #3167187
08/10/23 10:30 PM
08/10/23 10:30 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Is the choke special to the Hemi carb or could one from another make/model AFB be utilized ?
Re: Another Street Hemi Carb [Re: dragon slayer] #3167199
08/11/23 03:16 AM
08/11/23 03:16 AM
I am aware of that, and that’s what I said. This carb was on my 71 and it has the functioning original manual choke assembly. I may have the original choke for the earlier carb.
Re: Another Street Hemi Carb [Re: TJP] #3167382
08/11/23 08:31 PM
08/11/23 08:31 PM
VA
VA
Yes they are unique to Hemi. 66-67, 68-69, 70, 71 Manual. Each is a unique housing, several different internal pistons, and the thermostatic housing, 2 different versions. To be anatomically correct:-)
Almost all the ones on Ebay called hemi are not correct, and the other play on words is hiding reproduction part use.
Re: Another Street Hemi Carb [Re: dragon slayer] #3167438
08/12/23 09:40 AM
08/12/23 09:40 AM
You say the metering rod pistons differ too from year to year? confused
Re: Another Street Hemi Carb [Re: A727Tflite] #3167513
08/12/23 05:35 PM
08/12/23 05:35 PM
VA
VA
No the piston in the choke housing. 5 different versions.
Re: Another Street Hemi Carb [Re: dragon slayer] #3167531
08/12/23 08:30 PM
08/12/23 08:30 PM
Got it. up
