Re: Another Street Hemi Carb
[Re: dragon slayer]
#3166906
08/09/23 07:34 PM
08/09/23 07:34 PM
Posts: 3,073 Michigan
A727Tflite
It is out of the production window, over counter date code for a 67 hemi. Missing the choke which is an expensive part to replace as original. Even repo is expensive. So from my perspective a parts carb if someone needs good parts to repair a production line carb. But others may want it as is. 66-67 and even 68 are in less demand than the later carbs. I may have a choke for it. This carb was on my 71 Hemi GTX when I bought it, hence no need for the choke mechanism.
[Re: dragon slayer]
#3167187
08/10/23 10:30 PM
08/10/23 10:30 PM
Posts: 15,343 Omaha Ne
TJP
Omaha Ne
It is out of the production window, over counter date code for a 67 hemi. Missing the choke which is an expensive part to replace as original. Even repo is expensive. So from my perspective a parts carb if someone needs good parts to repair a production line carb. But others may want it as is. 66-67 and even 68 are in less demand than the later carbs. Is the choke special to the Hemi carb or could one from another make/model AFB be utilized ?
[Re: dragon slayer]
#3167199
08/11/23 03:16 AM
08/11/23 03:16 AM
A727Tflite
71 used a manual choke device for cable operation. I am aware of that, and that’s what I said. This carb was on my 71 and it has the functioning original manual choke assembly. I may have the original choke for the earlier carb.
