Stock 727 rebuild q's #3166220
08/07/23 11:42 AM
08/07/23 11:42 AM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
It's-a me, it only took a few more months for my 130k 1967 727 to start slipping in 3rd since I asked about odd behavior several weeks ago. I got away with a broken clutch friction disk (found in pan) for a little bit.
I am trying to figure out what I ought to replace with the kits + optional add-on parts available out there. It is still going to be behind a Magnum 318, likely still stock, maybe a mild cam in the future. I have had an auto trans apart once before but never a 727 so I am a bit blind, though I do know these things aren't terribly complicated to rebuild.
I've looked at a lot of different rebuild kits & sellers and Oregon Performance Transmission seems to have the best selector at least for picking out parts, maybe if not best parts outright. Can you guys advise if I'm selecting the right parts or if there are "while I'm in there" parts that really should be replaced that are missing?
https://www.oregonperformancetransmission.com/product/OPT-A727-RB.html
Master kit includes:
Friction clutch plates
Internal fluid filter
Intermediate kickdown band
Pump bushing
Output shaft bushing
All rubber clutch piston seals
All paper gaskets
All O-rings
All metal clad seals
Teflon and steel sealing rings
I assume it would be wise to add on a new low/reverse band, steel clutch plates, and a full kit of thrust washers and bushings given the mileage on my trans. Are any of these unnecessary or am I still missing anything else? Are any of these parts a particular PITA to R&R for an amateur garage dork?
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Stock 727 rebuild q's [Re: Secret Chimp] #3166221
08/07/23 11:49 AM
08/07/23 11:49 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Transtar Master Rebuild kit has everything you need and even includes the kickdown band (the other is extra).
https://www.transtar1.com/products/rebuild-kits
'63 Dodge 330
11.19 @ 121 mph
Re: Stock 727 rebuild q's [Re: GY3] #3166260
08/07/23 01:37 PM
08/07/23 01:37 PM
moparx Offline
moparx  Offline
the FSM, the book from monroe, plus a book from the ATSG [Automatic Transmission Service Group] will be all you need to rebuild a 727.
add a master rebuild kit, and any upgrade parts you desire, [servos, bands, etc.] and dive in.
those are the easiest of the automatic transmissions to rebuild.
but remember, "Cleanliness is next to Godliness" ! if you think it's clean, clean it at least two more times !
beer
Re: Stock 727 rebuild q's [Re: moparx] #3166315
08/07/23 04:12 PM
08/07/23 04:12 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I picked up a dvd on rebuilding the 727. www.technicalvideos.com part #12-727 phone#1-715-552-8016. This has been extremely helpful to me. I have Munroe's book but, I fared better with the dvd. It gives a complete tear down, what to look for, parts needed, assembly and testing.
Re: Stock 727 rebuild q's [Re: elmor353] #3166322
08/07/23 05:22 PM
08/07/23 05:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
No need to replace the rear band. Any kit with Raybestos or Borg Warner frictions will work. Its wise to wrap the front clutch piston seal with a large hose clamp and put it in the freezer before installing. They can be a bear. Air check the clutcth's on the bench before total assy. Drill a hole in the bench large enough for the reaction shaft to go thru. Set the the pump and both clutch assy's face down. Then air up each clutch thru it's pump feed hole.
Doug
Re: Stock 727 rebuild q's [Re: dvw] #3166833
08/09/23 02:30 PM
08/09/23 02:30 PM
Eugene, Oregon
Eugene, Oregon
Do I need a press for anything? I have air, a welder and a slide hammer
Re: Stock 727 rebuild q's [Re: Secret Chimp] #3166974
08/10/23 04:07 AM
08/10/23 04:07 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
It's late and I should be in bed,,
you need to get a couple pieces of 3/8-16 all-thread to use for slide/knockers to remove the front pump. Nuts and large washer on one end and a short piece of pipe or large socket to use as the knocker. A 36" piece is sold at the hardware stores.
The front drum will need press tool to disassemble and reassemble it. ebay sells cheap tranny clutch drum spring compressors or you can make your own. I've used a piece of 3/8" all-thread, scrap metal plate and a bench vice to compress the springs. ITEM 155707969259
ebay also sells a very nice seal and bearing driver kit.. I have several kits but this one beats all of them ITEM 393817772441
Like I said, it's late so I'm done.
ps, someone will fill you in on the other cool thing to fab up.
Re: Stock 727 rebuild q's [Re: Secret Chimp] #3167156
08/10/23 07:37 PM
08/10/23 07:37 PM
CA
crackedback Offline
crackedback  Offline
CA
Don't need a slide hammer. Take pump bolts out a ways or put longer ones in, stand trans on bell end and let gravity do the work. Pump comes out pretty easy. Sometimes I tag the tailshaft with a dead blow.
I don't usually even leave the bolts in, I take them out pop the bell on a piece of plywood and let the pump drop totally out. Some guys are sensitive about letting things hit the ground. I don't like to let the pump hit concrete.
Check youtube, plenty of good tear down and build videos for 727's.
Re: Stock 727 rebuild q's [Re: crackedback] #3167166
08/10/23 08:39 PM
08/10/23 08:39 PM
A727Tflite Online content
A727Tflite  Online Content
With a wide blade tool, valve body out, you can tap the pump out by placing that tool between the front drum and case.
