Tell me I'm nuts... #3166824
08/09/23 02:15 PM
08/09/23 02:15 PM
Nort Cackalacky
rrbrucea Offline OP
Member known as the "Artist"
rrbrucea  Offline OP
Nort Cackalacky
In just a bit I'm leaving to go look at this—1935 Dodge. If I bite the bullet, it'll become a hot rod. So I'm not so concerned about the fenders as there are fiberglass fenders available. It's all the other rust that makes me pause a bit. The door bottoms, cab bottom, side of the hood, etc. And that grille insert. At least an extra cab is included in the deal, a '34...
363532329_233045609706174_9135033557502193589_n.jpg363455458_304869638729618_1874754029565591161_n.jpg363795321_695437612625600_8054547281440565742_n.jpg363971196_864307815037981_5364003298997512047_n.jpg
Re: Tell me I'm nuts... [Re: rrbrucea] #3166829
08/09/23 02:25 PM
08/09/23 02:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
One heck of a lot of work. Good luck.
Re: Tell me I'm nuts... [Re: rrbrucea] #3166830
08/09/23 02:26 PM
08/09/23 02:26 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
OK; you're nuts laugh2
But I admire your optimism & fortitude !
Re: Tell me I'm nuts... [Re: rrbrucea] #3166831
08/09/23 02:27 PM
08/09/23 02:27 PM
Nort Cackalacky
rrbrucea Offline OP
rrbrucea  Offline OP
Nort Cackalacky
Those of you familiar with Kevin Goad's sweet rig, it's exactly what I'd be aiming for. Although I'm not sure about painting it red. Don't think we could have two red Dodge trucks from this era right here in North Carolina. laugh2
Re: Tell me I'm nuts... [Re: stumpy] #3166834
08/09/23 02:30 PM
08/09/23 02:30 PM
Nort Cackalacky
rrbrucea Offline OP
rrbrucea  Offline OP
Nort Cackalacky
I don't doubt it! This guy has had the stuff for years, and has done nothing with it... So I'm not as crazy about jumping in as I may have been when I was younger.
Re: Tell me I'm nuts... [Re: topside] #3166835
08/09/23 02:30 PM
08/09/23 02:30 PM
Nort Cackalacky
rrbrucea Offline OP
rrbrucea  Offline OP
Nort Cackalacky
LMAO, I asked for it!
Re: Tell me I'm nuts... [Re: rrbrucea] #3166837
08/09/23 02:37 PM
08/09/23 02:37 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
could be really neat
Those cabs are small
I bought one not long ago in western Nebraska and didn't make it back home before it sold ( just cab )
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Tell me I'm nuts... [Re: bigdad] #3166841
08/09/23 02:47 PM
08/09/23 02:47 PM
Nort Cackalacky
rrbrucea Offline OP
rrbrucea  Offline OP
Nort Cackalacky
And I'm NOT! laugh2
Re: Tell me I'm nuts... [Re: rrbrucea] #3166842
08/09/23 02:48 PM
08/09/23 02:48 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I sold just a cab and admittingly it was a dry as a chicken bone for $1800
Re: Tell me I'm nuts... [Re: bigdad] #3166849
08/09/23 03:01 PM
08/09/23 03:01 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I don't know how big of a person you are, but I'm 6' 1" tall and 270lbs. and getting in and out of a 39 Dodge was hard enough I sold it after I got it built. A 34 cab is smaller then a 39 cab is. If you can get in and sit inside for a bit before you lay down your money and drag it home, to be able to make sure you fit would be a great idea.
They are a lot of work to build. Finding parts like the grille and such will be like finding hen's teeth, then buying them will make the prices of OEM Hemi Cuda convertible parts seem cheap. Expect to have to build, rebuild, or fabricate from what every you bring home.
Oh yea, just because they "make" glass fenders, that doesn't mean there are any available when you want them, it just means some have been made. Glass fenders are run in batches, the sold until they are gone. Then when there is enough demand, they run another batch. It may have been years since the last batch was run, and it could be years before the next batch is run, but they make them.
Re: Tell me I'm nuts... [Re: poorboy] #3166855
08/09/23 03:28 PM
08/09/23 03:28 PM
Nort Cackalacky
rrbrucea Offline OP
rrbrucea  Offline OP
Nort Cackalacky
Thank you, that's the exactly the kind of realistic response I need. I'm 6' and 215 pounds, so not really "huge," but I am accustomed to my 2014 Ram... biggrin
I've never really messed with stuff from the '30s, so there would likely be a learning curve with stuff that's not from the '60s or '70s for me. I did think I might try to actually get IN the cab, but since there's nothing left in there but the seat springs, I don't know how realistic that might be.
Re: Tell me I'm nuts... [Re: rrbrucea] #3166862
08/09/23 03:38 PM
08/09/23 03:38 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I badly want a '32 Ford roadster or roadster pickup but I'm 6'2" and 215 lbs. as well. I've tried a few on for size (even the Brookville) and no bueno!
That Dodge does look like a cool piece, though!
'63 Dodge 330
11.19 @ 121 mph
Re: Tell me I'm nuts... [Re: rrbrucea] #3166865
08/09/23 03:43 PM
08/09/23 03:43 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Dents in those older rounded fenders are not that difficult to get out even if they look really bad. Hammer + dolly + shrinking disc action would bring them back around.
Better to fix them than buy fiberglass parts that will be wavy and require way more prep time than people realize. Most of the that 'glass stuff does not just bolt on and fall into place. You'll have weird gaps and alignment issues that will need to be addressed too.
Re: Tell me I'm nuts... [Re: Neil] #3166866
08/09/23 03:51 PM
08/09/23 03:51 PM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
As nice as the red truck looks, it might be a little easier if you go for the patina look. I don't want to go so far as to say 'rat rod' but some happy middle ground. Get it running driving, then focus on making it look pretty. I've seen a few trucks (all brands) where the cab was extended 4"-6" to give more room, but that may be beyond the scope of this project.
John
Re: Tell me I'm nuts... [Re: SattyNoCar] #3166885
08/09/23 05:54 PM
08/09/23 05:54 PM
CrazyD Offline
CrazyD  Offline
not mine, but here is a "restored" 35 for $28K. Might be way cheaper in the long run...
1935 Dodge D100 Pickup
Re: Tell me I'm nuts... [Re: CrazyD] #3166904
08/09/23 07:28 PM
08/09/23 07:28 PM
Nort Cackalacky
rrbrucea Offline OP
rrbrucea  Offline OP
Nort Cackalacky
Well, I went, I saw, and I passed. Perhaps I’m not nuts after all? I don’t really know one way or the other… the reality is, there are two cabs there because it’s going to take both to make one good one. Inside the cab wasn’t unbearable other than the steering wheel being in your chest. That would be solved with some aftermarket column, say from Flaming River or something comparable. Bottom line, the owner has had it for around 20 years and there it sits. The 30s Dodge trucks are beautiful, but this particular truck is beyond my abilities to save. Especially since I’m no longer a young guy. I’ll stick with tweaking on my Barracuda. 👍
Re: Tell me I'm nuts... [Re: rrbrucea] #3166908
08/09/23 07:42 PM
08/09/23 07:42 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
While I COMPLETELY understand temptations, probably a prudent decision to pass.
I'd say if you do metal work and have the time something like this would be really cool though.
Facts are stubborn things.
Re: Tell me I'm nuts... [Re: rrbrucea] #3166968
08/10/23 12:06 AM
08/10/23 12:06 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
OK. You aren't nuts... grin
Re: Tell me I'm nuts... [Re: Ramrod39] #3166988
08/10/23 07:21 AM
08/10/23 07:21 AM
Nort Cackalacky
rrbrucea Offline OP
rrbrucea  Offline OP
Nort Cackalacky
Re: Tell me I'm nuts... [Re: rrbrucea] #3167035
08/10/23 10:32 AM
08/10/23 10:32 AM
my own world
theraif Offline
theraif  Offline
my own world
grin
