Looking forward to a first outing this weeked
#3166430
08/08/23 07:39 AM
08/08/23 07:39 AM
Posts: 12,404 Taxes & Virus's R-US, NY
Dragula
Now that I am done fighting with the FW in the Holley sniper, we have the Nostalgia Gold (old) Cup this Saturday, and hoping for a first outing with the Hemi Cuda....Almost ended up putting the carb back on it. But thanks to a helpful Dr. EFI, I was able to get it updated.
So last year at the end of the season, I ran the car, and it went a mid 6 with a broken valve spring and spun another bearing...This was after driving it all summer to all the cruise nights and such and working out the cooling system bugs. Plus the logger showed it dead lean for 0.5s off the hit.
So over the winter, we put the same rotating assembly in a new block, with all new bearings, and I coated the block with Glyptol, and added intake valve spring spray bars. We also put smaller restrictors in, and I am running an extra quart in the oil pan after checking the oil depth in it, and we removed the restrictive windage tray. Also went to a milder ramp on the cam which is now a lot tighter lash than the old school one we had, and lowered open spring pressure to #180 from #230, by changing valve springs....
All this for a better street/strip experience and longer engine life. I have another short block in the works as a spare.
The weather is not looking good for Saturday, so who knows at this point...But it is my 52nd birthday!
Re: Looking forward to a first outing this weeked
[Re: Dragula]
#3166443
08/08/23 08:41 AM
08/08/23 08:41 AM
Posts: 17,896 S.E. Michigan
ZIPPY
S.E. Michigan
Good luck Randy.
I like the idea of changing it to enhance the street aspect.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3166489
08/08/23 11:06 AM
08/08/23 11:06 AM
Dragula
Good luck Randy.
I like the idea of changing it to enhance the street aspect. Well last year I also went to 3.73 rear gear from 4.10, and that made it so streetable, it was like night and day. Now we need a happy engine that will drive all over, and go fast, like 9.80 or quicker. The trans holds up well, but I want to upgrade that to a Trans Brake and use a two step...and maybe a low gear kit. The Hemi is not like a wedge. You don't put a big cube stroker together, and slap a good set of heads on it, these really need attention to oiling & drain back.
[Re: Dragula]
#3166580
08/08/23 03:16 PM
08/08/23 03:16 PM
ZIPPY
S.E. Michigan
You don't? OK. I will make sure I stay out of trouble with mediocre heads, restrictive induction and tiny camshafts LOL.
As said on the phone, I'm really not interested in going 9s or 8s in any car that I currently own, so I'll live vicariously through those who do and cheer you on.
Have a great birthday.
Rich H.
Esse Quam Videri
[Re: FastmOp]
#3166663
08/08/23 08:56 PM
08/08/23 08:56 PM
Dragula
Scratch that idea....Fans & water pump wiring that worked last year, none of it works after the new install....And its a real pain in the butt to get to it. So I doubt I am running anything this week.....The car has earned its name well over the years...CURSED!
[Re: FastmOp]
#3166734
08/09/23 07:59 AM
08/09/23 07:59 AM
Posts: 4,077 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I enjoy your outings, we all fight gremlins. Keep it up. AGREE, keep after it and you'll get it. Good luck and Happy birthday!
[Re: HardcoreB]
#3166739
08/09/23 08:24 AM
08/09/23 08:24 AM
ZIPPY
S.E. Michigan
This has the hidden engine compartment wiring, doesn't it?
Rich H.
Esse Quam Videri
[Re: Dragula]
#3166870
08/09/23 04:10 PM
08/09/23 04:10 PM
Posts: 8,030 Tulsa OK
Bad340fish
Tulsa OK
The ARC switch panel is where the radio went, and the wiring goes from there to some relays somwhere, and then out to the engine bay thru the door hinge area...The problem is getting to the ARC switch panel and checking the fuses and wires. Passenger seat has to come out, and the somehow crawl under the dash.... If I ever rewire my car again I am going to put everything in the triangle of the passenger door bar and the main hoop. I recently moved my EFI controller up on the bottom of my dash to get it out from under the seat. Next move is getting the rest out from under the dash, I hate it!
68 Barracuda Formula S 340
[Re: Bad340fish]
#3167058
08/10/23 12:17 PM
08/10/23 12:17 PM
Posts: 19,378 Las Vegas
Al_Alguire
Las Vegas
Excuse the mess but I have doing it for years. BTW I also LOVE the Speedwire stuff
[Re: Dragula]
#3167764
08/14/23 07:23 AM
08/14/23 07:23 AM
Dragula
Well, got a look at the wiring I put in last year from Painless, and its all wired right and nice and neat, but the fans must be drawing a bit more than last year, and the Painless kit was pre-wired, and I smoked all the wires to the fan furthest away. Not to mention the water pump won't come on, so I think one relay is dead. This kit should have been enough to run everything. Worked all last year. I looked up the fans I bought from Wizard Cooling, and they are rated at 21amps, but I think they pull more. The Painless kit does not say what size wiring or ratings its built to, but tain't working this year. Going to have to re-wire everything with a Leash Pro 8 relay board I think....It least those are rated 70 amps, and I will wire everything with 10ga...for next year. I give up for this year because I also need treaded street tires and rims, its been raining every other day like crazy here, and I can't get caught with DOT slicks on it. https://proshop.summitracing.com/parts/prf-30117https://leashelectronics.com/products/pro8-relay-module
[Re: Dragula]
#3168026
08/15/23 08:35 AM
08/15/23 08:35 AM
Posts: 13,379 Marion, South Carolina [><]
an8sec70cuda
This car has given you a fit! Good luck w/ it Randy.
