Re: Magnum 500 wheels
[Re: DusterKid]
#3165114
08/02/23 02:15 PM
08/02/23 02:15 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Does anyone happen to make a magnum 500 wheel in a 15x4? I wish , I'd be in for a set.
[Re: Old_Moparz]
#3165535
08/04/23 10:49 AM
08/04/23 10:49 AM
JohnRR
U.S.S.A.
BUT ... it's not 4" BP , smallest is 4.5 .. that's a 4" wide wheel.
[Re: DusterKid]
#3165552
08/04/23 12:36 PM
08/04/23 12:36 PM
Posts: 19,470 north of coder
moparx
Does anyone happen to make a magnum 500 wheel in a 15x4? taking that question as written, i would think the quest is for a 4" wide wheel. if the OP was looking for a 4" bolt pattern wheel, i would think the 4" bolt pattern would have been mentioned, such as : "does anyone happen to make a magnum 500 wheel with a 5x4" bolt pattern ?" just my take. your mileage will vary.
[Re: JohnRR]
#3165691
08/05/23 01:58 AM
08/05/23 01:58 AM
Posts: 623 Zombieland
Car Nut
Zombieland
BUT ... it's not 4" BP , smallest is 4.5 .. that's a 4" wide wheel. Where did you see backspacing in the OP’s post? 15x4 means 15 inch rim 4 inches wide. I don’t see backspace. Does anyone happen to make a magnum 500 wheel in a 15x4?
[Re: moparx]
#3166171
08/07/23 08:45 AM
08/07/23 08:45 AM
Posts: 3,457 Newburgh, NY
Old_Moparz
Newburgh, NY
Does anyone happen to make a magnum 500 wheel in a 15x4? taking that question as written, i would think the quest is for a 4" wide wheel. if the OP was looking for a 4" bolt pattern wheel, i would think the 4" bolt pattern would have been mentioned, such as : "does anyone happen to make a magnum 500 wheel with a 5x4" bolt pattern ?" just my take. your mileage will vary. That's how I understood it.
[Re: DusterKid]
#3166203
08/07/23 11:02 AM
08/07/23 11:02 AM
Old_Moparz
Newburgh, NY
I'm looking for a 15x4 wheel. 5 x 4.5 bolt pattern. I don't think they even make the Magnum 500 in a 5x4 bolt pattern, but even if they did, I changed my car over to the 5 x 4.5 pattern. No, they never did & it's too bad they didn't because they are one of my favorite factory mags.
[Re: Old_Moparz]
#3166347
08/07/23 07:11 PM
08/07/23 07:11 PM
Posts: 1,459 oklahoma
forphorty
oklahoma
I'm looking for a 15x4 wheel. 5 x 4.5 bolt pattern. I don't think they even make the Magnum 500 in a 5x4 bolt pattern, but even if they did, I changed my car over to the 5 x 4.5 pattern. No, they never did & it's too bad they didn't because they are one of my favorite factory mags. It's too bad they didn't make all the cars 4.5 to begin with.
[Re: forphorty]
#3166447
08/08/23 08:54 AM
08/08/23 08:54 AM
Posts: 17,864 S.E. Michigan
ZIPPY
S.E. Michigan
I'm going to state the obvious, just skip this if it's a waste of time or whatever.
With wheels, because they are an exterior item, the lack of commonization is a profit driver.
There was just as much reason for the Dakota to be changed to 6 lug after it was introduced, as there was for the older A bodies to be introduced with a 4" bolt pattern.
Marketing/product planning knows consumers usually want something that looks different for no reason other that the appearance, and what better way to accomplish that and sell more parts than to unnecessarily make certain parts specialized. The wheel manufacturers make more money too, "everyone wins" and it's all driven by the starry eyed consumer who insists on everything being "new design".
If you like a certain wheel, the car companies greatly prefer you to purchase the entire car rather than just the wheel.
Rich H.
Esse Quam Videri
[Re: DusterKid]
#3166475
08/08/23 10:41 AM
08/08/23 10:41 AM
JohnRR
U.S.S.A.
I'm looking for a 15x4 wheel. 5 x 4.5 bolt pattern. I don't think they even make the Magnum 500 in a 5x4 bolt pattern, but even if they did, I changed my car over to the 5 x 4.5 pattern. My bad , I ASSuMEd by your name , DUSTERkid that you were looking for 4" Bolt Pattern wheels ...
[Re: Car Nut]
#3166476
08/08/23 10:42 AM
08/08/23 10:42 AM
JohnRR
U.S.S.A.
BUT ... it's not 4" BP , smallest is 4.5 .. that's a 4" wide wheel. Where did you see backspacing in the OP’s post? 15x4 means 15 inch rim 4 inches wide. I don’t see backspace. Does anyone happen to make a magnum 500 wheel in a 15x4? I misunderstood his question going off his screen name
[Re: forphorty]
#3166478
08/08/23 10:44 AM
08/08/23 10:44 AM
JohnRR
U.S.S.A.
I'm looking for a 15x4 wheel. 5 x 4.5 bolt pattern. I don't think they even make the Magnum 500 in a 5x4 bolt pattern, but even if they did, I changed my car over to the 5 x 4.5 pattern. No, they never did & it's too bad they didn't because they are one of my favorite factory mags. It's too bad they didn't make all the cars 4.5 to begin with. Or 4.75 for that matter , then my favorite mag wheels wouldn't be unilug pattern ...
[Re: JohnRR]
#3166528
08/08/23 12:39 PM
08/08/23 12:39 PM
moparx
i'm not a fan of unilug wheels in any application. yes, i have ran them without any troubles in the way distant past, but my preference and opinion has changed since. i now prefer hub-centric wheels, or wheels i can buy or fabricate hub-centric rings for, in the specific bolt pattern the application calls for. just an old man's preference these days. your mileage will vary.
[Re: JohnRR]
#3166721
08/09/23 06:33 AM
08/09/23 06:33 AM
Car Nut
Zombieland
