seam sealer question #3164518
07/31/23 12:52 PM
07/31/23 12:52 PM
moparx Offline OP
moparx  Offline OP
i pulled the carpet out of my 69 charger because i have a new replacement set. this is the original carpet, and although the car is just about to turn 19k original miles, the carpet has been deteriorating for many years. this is even while being a garage queen and not driven since at least 2006 or so.
while scratching the floor pan with a wire brush by hand to get rid of some loose paint and leftover horse hair backing material, i hit several sections of seam sealer, and it fell off in large chunks, like it lost it's adhesion. [which of course it did !]
i then used a hand scraper, and most of it came off by just touching it with the scraper. no effort needed whatsoever.
what was used back then, and what would be a good replacement sealer to use ?
TIA for the knowledge you folks have that i do not. bow
beer
Re: seam sealer question [Re: moparx] #3164528
07/31/23 01:29 PM
07/31/23 01:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: seam sealer question [Re: Alaskan_TA] #3164556
07/31/23 02:41 PM
07/31/23 02:41 PM
moparx Offline OP
moparx  Offline OP
which should be used ? the brushable, or the cartridge stuff ? or both ?
thanks Barry. bow
beer
Re: seam sealer question [Re: moparx] #3164686
07/31/23 08:50 PM
07/31/23 08:50 PM
MO
cdp Offline
cdp  Offline
MO
I've had really good luck with Wurth brand brushable seam sealer. Goes on excellent and flows easy, remains flexible when dry and dries fast. If you're looking for an OE look, RestoRick has some product available.
https://www.wurthusa.com/Chemical-P...hable-Seam-Sealer-1-Quart-Can/p/08901021
3m's brushable is crap. Too stiff, cracks when it dries.
Re: seam sealer question [Re: cdp] #3164774
08/01/23 09:28 AM
08/01/23 09:28 AM
moparx Offline OP
moparx  Offline OP
this doesn't have to be a restoration product, as i'm only looking to seal up the seams where the original product has lost it's grip.
i'm also thinking the seams need resealed before i apply whatever paint/coating on the floor i decide to use ?
beer
Re: seam sealer question [Re: moparx] #3164793
08/01/23 10:52 AM
08/01/23 10:52 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
3M, Fusor, Wurth, etc - used them all over the last 40 years, and can't recall any issues when used correctly & for the right application.
What gets used is more an issue of duplicating a factory appearance where it's visible.
For the floor under the carpet, pretty much any of them are fine.
I tend to use cartridges, and then a brush to spread it, if that's what the factory did.
Re: seam sealer question [Re: topside] #3164851
08/01/23 02:11 PM
08/01/23 02:11 PM
South Dakota
hotairballoonpilot Offline
South Dakota
I love the 3M brushable sealers. dries nice and hard compared to other sealers that are more rubbery like. just use the brushable in a well ventilated area, you will get a buzz
Contact Me about AMD Prices
Re: seam sealer question [Re: hotairballoonpilot] #3164867
08/01/23 02:59 PM
08/01/23 02:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yeah, I forgot about the bonus ! laugh2
Re: seam sealer question [Re: topside] #3165035
08/02/23 10:27 AM
08/02/23 10:27 AM
moparx Offline OP
moparx  Offline OP
as if i need to get any goofier than i already am....... runaway panic laugh2
beer
Re: seam sealer question [Re: moparx] #3165061
08/02/23 11:53 AM
08/02/23 11:53 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
You know, I might have some left.
Would need to check but I think I have an almost full quart can of a generic brush on that I didn't use, and cartridges of 3M urethane.
It'll probably all hit it's shelf life before I use it. Let me know if you need any.
You can have the brushable for free/I just didn't like working with it/nasty stuff. Prefer caulk tube cartridges.
I'd attempt to sell the 3m for whatever it was I paid off Amazon, 20 something apiece.
Rather do that than toss it a year from now.
Rich H.
Esse Quam Videri
Re: seam sealer question [Re: moparx] #3166109
08/06/23 10:08 PM
08/06/23 10:08 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
19000 miles wow in 54 years that is a little over 350 miles a year.
My opinion would be to just remove the old sealer and not install any replacement.
The car does not need it.
Maybe leave a note under the new carpet with your name and date with the cars mileage and saying that you removed the failing seam sealer.
Re: seam sealer question [Re: ZIPPY] #3167062
08/10/23 12:34 PM
08/10/23 12:34 PM
moparx Offline OP
moparx  Offline OP
thanks for the generous offer Zippy ! up bow
however, my one buddy here has some left over from a project done a few months ago that will work for me.
beer
