Re: CAN YOU SEE IF A MESSAGE HAS BEEN READ?
[Re: Magnumguy]
#3164071
07/29/23 10:47 AM
07/29/23 10:47 AM
Posts: 16,841 Between Houston & Galveston TX
SattyNoCar
WHY ARE YOU YELLING? I MAY BE BLIND BUT I AIN'T DEAF!! Anyways...... Look at the message you sent, on the lower left below your screen name and all that, you'll see 'unread'. If its been read, it'll show 'none' If it hasn't been read, it'll show a screen name.
John
[Re: SattyNoCar]
#3164076
07/29/23 11:05 AM
07/29/23 11:05 AM
Posts: 20,029 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
WHY ARE YOU YELLING? I MAY BE BLIND BUT I AIN'T DEAF!! Let's just be grateful that it was posted in General instead of Q&A. People often post these kinds of things in Q&A. When the post gets moved to General, the person who posted the initial topic will post another topic (typically also in Q&A) entitled "WHERE DID MY POST GO" or other similar ridiculousness.
Earning every penny of that moderator paycheck.
DBAP
[Re: not_a_charger]
#3164090
07/29/23 11:50 AM
07/29/23 11:50 AM
Posts: 10,651 S.E.Ohio
Magnumguy
S.E.Ohio
WHY ARE YOU YELLING? I MAY BE BLIND BUT I AIN'T DEAF!!. Huh? Anyway, thanks for the tip
[Re: Magnumguy]
#3164092
07/29/23 11:54 AM
07/29/23 11:54 AM
not_a_charger
WHY ARE YOU YELLING? I MAY BE BLIND BUT I AIN'T DEAF!!. Huh? Anyway, thanks for the tip He's referring to the use of all caps. Typing in all caps is generally considered "yelling" in written form.
DBAP
[Re: Magnumguy]
#3164096
07/29/23 12:07 PM
07/29/23 12:07 PM
SattyNoCar
Sorry, but I always type my title in caps. I forgot you do this, my bad. But as not_a_charger stated, caps are usually considered yelling. I'll try to remember next time...........
John
[Re: Magnumguy]
#3164173
07/29/23 07:51 PM
07/29/23 07:51 PM
Posts: 6,325 nowhere
Sniper
nowhere
I do the caps so I can find my posts easier. I'll try not to yell as loud next time Make it easy on all of us Click on your username then select show forum posts It will show all YOUR posts.
[Re: Sniper]
#3164180
07/29/23 08:23 PM
07/29/23 08:23 PM
SattyNoCar
John
[Re: Sniper]
#3164184
07/29/23 08:34 PM
07/29/23 08:34 PM
Posts: 22,731 Bitopia
jcc
Bitopia
There are studies that show in order to read and understand another's thoughts promptly, its first most important to recognize the fisrt and last letters of each word, as long as most of the rest letters are included and the word has the correct number of letters, regardless of if they are in perfect order or not, the brain understands/recognizes the word and moves on to the next word. CAPITALS upset that process. It's not the stated perceived "yelling", it's the awkwardness of reading all capitals that is the issue. Your grade school teacher and spelling bee winners are likely to completely disagree with this thinking. Mark Twain also had something related to say on this topic. An Exhibit below from the San Fransisco Exploratorium:
