Re: Interior lights come on when I apply the brakes
[Re: 340mouse]
#3161394
07/20/23 05:39 PM
07/20/23 05:39 PM
Posts: 2,383 White Plains, NY
VCODE
White Plains, NY
Try checking ALL your fuses to see if the are ALL good. Everyone of them
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: GomangoCuda]
#3161401
07/20/23 06:26 PM
07/20/23 06:26 PM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Grounds and then bulbs themselves. I had an internal short in one that turned on my park light. Would be weird to do an inside light.
I want my fair share
[Re: SomeCarGuy]
#3161433
07/20/23 07:32 PM
07/20/23 07:32 PM
Posts: 1,839 South Bend
John Brown
South Bend
Had a customer years ago with the same complaint. Turned out to be a blown brake light fuse.
[Re: A12]
#3161511
07/20/23 11:06 PM
07/20/23 11:06 PM
Posts: 275 Oakwood Ont Canada
340mouse
Oakwood Ont Canada
These members have some good suggestions. I too think it's a ground problem. But until you figure it out, maybe put a red translucent cover over the interior dome light and have the first ('68) car with a third/high mount brake light. Sorry just joking. Maybe pull one brake light bulb out at a time and check the result? Thanks for the humour, I needed that, fix 1 thing break another over and over again last 3 weeks, hopefully I pinched an obvious wire today. I hope! Dave
[Re: 340mouse]
#3161576
07/21/23 10:56 AM
07/21/23 10:56 AM
Posts: 10,731 North Dakota
6PakBee
North Dakota
The interior lights light because the door switches ground the lights or the headlight switch grounds the lights. I'd look at the headlight switch.
[Re: John Brown]
#3162855
07/24/23 06:08 PM
07/24/23 06:08 PM
340mouse
Oakwood Ont Canada
Had a customer years ago with the same complaint. Turned out to be a blown brake light fuse. This is what it turned out to be, my wiring harness looks suspect, better start saving now. Thanks for the help guys. Dave
[Re: moparx]
#3163148
07/25/23 04:55 PM
07/25/23 04:55 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
I even got my finger burned when I touched it!
About the heat… think on the cigar lighter!
Bulbs itself! Headlights! Everything of that are heating elements on 12 volts circuits.
