Interior lights come on when I apply the brakes #3161393
07/20/23 05:32 PM
07/20/23 05:32 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
My 68 Cuda, converted to front discs and redid all brakes, then off for FE alignment, the best it had drove ever but my Speedo quit on the way home, had to retighten the lines into the new prop valve and got the speedo cable back into the dash, now the interior lights come on dim when brakes are applied, done for the day!, hopefully figure that out tomorrow. Any thoughts.
Re: Interior lights come on when I apply the brakes [Re: 340mouse] #3161394
07/20/23 05:39 PM
07/20/23 05:39 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Try checking ALL your fuses to see if the are ALL good. Everyone of them
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: Interior lights come on when I apply the brakes [Re: 340mouse] #3161397
07/20/23 05:57 PM
07/20/23 05:57 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Check grounds for all lights.
Re: Interior lights come on when I apply the brakes [Re: GomangoCuda] #3161401
07/20/23 06:26 PM
07/20/23 06:26 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Grounds and then bulbs themselves. I had an internal short in one that turned on my park light. Would be weird to do an inside light.
I want my fair share
Re: Interior lights come on when I apply the brakes [Re: SomeCarGuy] #3161433
07/20/23 07:32 PM
07/20/23 07:32 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Had a customer years ago with the same complaint. Turned out to be a blown brake light fuse.
Re: Interior lights come on when I apply the brakes [Re: John Brown] #3161473
07/20/23 09:31 PM
07/20/23 09:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
My guess might be the brake lights have a flaky ground and are getting their ground through the dome lamp circuit which also includes the glove box and trunk lights.
What happens with the 4 way flashers or turn signals?
Re: Interior lights come on when I apply the brakes [Re: 340mouse] #3161504
07/20/23 10:35 PM
07/20/23 10:35 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
These members have some good suggestions. I too think it's a ground problem. But until you figure it out, maybe put a red translucent cover over the interior dome light and have the first ('68) car with a third/high mount brake light. wink Sorry just joking. Maybe pull one brake light bulb out at a time and check the result?
Re: Interior lights come on when I apply the brakes [Re: A12] #3161506
07/20/23 10:38 PM
07/20/23 10:38 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
If you have recently worked on the left door sill or the left kick panel remove the screws again and check if that solves the issue? DAMHIK. I did that with my '68 RR and inadvertently ran a screw through a couple of wires.
Re: Interior lights come on when I apply the brakes [Re: A12] #3161511
07/20/23 11:06 PM
07/20/23 11:06 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
Thanks for the humour, I needed that, fix 1 thing break another over and over again last 3 weeks, hopefully I pinched an obvious wire today. I hope! Dave
Re: Interior lights come on when I apply the brakes [Re: 340mouse] #3161576
07/21/23 10:56 AM
07/21/23 10:56 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The interior lights light because the door switches ground the lights or the headlight switch grounds the lights. I'd look at the headlight switch.
Re: Interior lights come on when I apply the brakes [Re: 340mouse] #3161777
07/21/23 10:08 PM
07/21/23 10:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Check your grounds especially at the tail brake sockets. Migt try a jumper from say the bumper or clean metal spot to the socket housing wink
Re: Interior lights come on when I apply the brakes [Re: John Brown] #3162855
07/24/23 06:08 PM
07/24/23 06:08 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
This is what it turned out to be, my wiring harness looks suspect, better start saving now. Thanks for the help guys. Dave
Re: Interior lights come on when I apply the brakes [Re: 340mouse] #3162905
07/24/23 08:48 PM
07/24/23 08:48 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
thumbs
Re: Interior lights come on when I apply the brakes [Re: John Brown] #3163093
07/25/23 02:21 PM
07/25/23 02:21 PM
moparx Offline
moparx  Offline
glad it was a simple, and super inexpensive, repair. up
however, if the harness looks suspect, replacement sooner rather than later, is the way to go.
beer
Re: Interior lights come on when I apply the brakes [Re: moparx] #3163097
07/25/23 02:25 PM
07/25/23 02:25 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I have had same problem floating on quite often, and was a brake lights fuse related problem, but not because blowing… some bad contact at fuse clips. This bad contact was able to heat enough to melt the fusebox whiney
Re: Interior lights come on when I apply the brakes [Re: NachoRT74] #3163115
07/25/23 03:17 PM
07/25/23 03:17 PM
moparx Offline
moparx  Offline
it is kind of amazing just how much heat can be caused by a bad contact/resistance in a simple 12 volt system ! eek panic
beer
Re: Interior lights come on when I apply the brakes [Re: moparx] #3163148
07/25/23 04:55 PM
07/25/23 04:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I even got my finger burned when I touched it!
About the heat… think on the cigar lighter!
Bulbs itself! Headlights! Everything of that are heating elements on 12 volts circuits.
Re: Interior lights come on when I apply the brakes [Re: NachoRT74] #3163310
07/26/23 10:17 AM
07/26/23 10:17 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Never would have guessed that. work
