Torque Converter #3161112
07/19/23 06:45 PM
07/19/23 06:45 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
70 challenger 440 mag with 727 trans. When problem 1st started i would put car in reverse getting it out of garage and tires would chip and engine would die this would happen a couple of times till car would stay running when in gear. Now something is making a awful noise like something hitting sheet metal, I thought starter was not disengageing completey but that was fine. Would a bad torque converter make that sound ? If so how would I check it ?
thanks
Rod
Re: Torque Converter [Re: ct440rod] #3161124
07/19/23 07:34 PM
07/19/23 07:34 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Check the bolts on the flexplate to make sure one or some haven't backed out.
Re: Torque Converter [Re: Fat_Mike] #3161184
07/19/23 09:20 PM
07/19/23 09:20 PM
iagree wrench scope up
Do the easy stuff first grin
Re: Torque Converter [Re: Cab_Burge] #3168463
08/17/23 09:56 AM
08/17/23 09:56 AM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Everything is nice and tight can not see anything wrong. If you go to this link you can listen to noise,
https://www.youtube.com/shorts/m69aih_hqBQ
Re: Torque Converter [Re: ct440rod] #3168508
08/17/23 12:31 PM
08/17/23 12:31 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Sounds like something is hitting the inspection cover shruggy
Re: Torque Converter [Re: B1MAXX] #3168514
08/17/23 12:46 PM
08/17/23 12:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Agree ,
Take off the sheetmetal cover , if something is hitting it like that then you will see a circular scrape
Re: Torque Converter [Re: JohnRR] #3169226
08/20/23 03:09 PM
08/20/23 03:09 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
Took inspection cover off and still making same noise
Re: Torque Converter [Re: ct440rod] #3169283
08/20/23 07:34 PM
08/20/23 07:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Try moeving the convertor clockwise and counter clockwise by hand to see if the flex plate to crank bolts are tight.
Re: Torque Converter [Re: ct440rod] #3169331
08/20/23 10:54 PM
08/20/23 10:54 PM
I'm not hearing what your talking about, I think confused
Re: Torque Converter [Re: Cab_Burge] #3176039
09/18/23 01:07 PM
09/18/23 01:07 PM
Milan Ohio
ct440rod Offline OP
ct440rod  Offline OP
Milan Ohio
