74 Dart Custom Brakes #316001
05/12/09 04:05 PM
05/12/09 04:05 PM
kentucky
P
psepter Offline OP
psepter  Offline OP
P
kentucky
I have the 8 1/4 axle from a 74 Dart Custom. The axle has 11" brakes on it. Have anyone heard of this before and what car could I look up so I could get the right size.
Re: 74 Dart Custom Brakes [Re: psepter] #316002
05/12/09 04:39 PM
05/12/09 04:39 PM
your parts hose is telling you there is no listing for linings/wh cyls/hardware kits for 11" brakes on a 74 A body?. I would get some smaller dia wheel cyls from Rick Ehrenberg and I believe a listing for any(70's) 11" application for the linings/hardware kits will work(try a 70's B body. there was a change on the shape of the hole in the shoe webb where the vertical e brake lever pivot fits into in about 76 or 77 but I think they all interchange. Just take one of your levers in with you & hook it into one of the shoes they pull out for you.
Re: 74 Dart Custom Brakes [Re: RapidRobert] #316003
05/13/09 10:14 AM
05/13/09 10:14 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
I would get some smaller dia wheel cyls from Rick Ehrenberg .....
Thanks for the plug, and Amen to that. 11" drums on the rear of an A-body!..as if the stock proportioning wasn't bad enough!
Rick
Re: 74 Dart Custom Brakes [Re: Rick_Ehrenberg] #316004
05/13/09 01:46 PM
05/13/09 01:46 PM
scratchnfotraction Offline
you need to measure the width of the shoe for the 11" drum 2" 2.5"
ask for b-body or c-body brakes 11x2.5 ect..
whats wrong with 11" brakes on the A-body?
I swaped my 68 dart to 73 manual disc with stock prop valve
used a 4 bolt to 2 bolt MP adapter,used the large diam 2 bolt alum mc,used the lagest wheel cyl for c-body 11"x2.5 drums on my 8 3/4 rear axle
even up it to the r-body 12" front disc and added the cooling tube to the splash sheild
never had a problem and it would stop very quik from high speeds
Re: 74 Dart Custom Brakes [Re: scratchnfotraction] #316005
05/13/09 02:08 PM
05/13/09 02:08 PM
kentucky
P
psepter Offline OP
psepter  Offline OP
P
kentucky
The shoes measured 2". Every parts place tells me that they cant find them listed for anything.
Re: 74 Dart Custom Brakes [Re: psepter] #316006
05/13/09 02:20 PM
05/13/09 02:20 PM
I have seen 11x 2" on a 72 4x4
and on a 96 ram 1500
take any that are 11x2 IMO
try a 73 newport its a c-body
try a 76 dodge charger se,seemed mine was 11x2 on that one also
or tell them to find any listing that has a 11x2 drum with 5 on 4.5 wbp
seems my 85 truck was 11x2 also
Re: 74 Dart Custom Brakes [Re: scratchnfotraction] #316007
05/13/09 02:34 PM
05/13/09 02:34 PM
kentucky
P
psepter Offline OP
psepter  Offline OP
P
kentucky
Thank You
