mopar block P51588848 #3159218
07/12/23 10:29 PM
07/12/23 10:29 PM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
Anyone know of this style block? Is it 4.5 bore capable? TY!!
Re: mopar block P51588848 [Re: sean1970] #3159253
07/13/23 02:00 AM
07/13/23 02:00 AM
NY
B1duster Offline
B1duster  Offline
NY
Are you sure about that number ? I see a P5153843 mopar World block
Re: mopar block P51588848 [Re: B1duster] #3159350
07/13/23 09:48 AM
07/13/23 09:48 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If it’s like an R3 the casting numbers on the block are nearly meaningless….. the number on the box it came in told the story.
Re: mopar block P51588848 [Re: B1duster] #3159351
07/13/23 09:48 AM
07/13/23 09:48 AM
Houston, Texas
sean1970 Offline OP
sean1970  Offline OP
Houston, Texas
Attached a picture of the number. TY Sean
Re: mopar block P51588848 [Re: sean1970] #3159364
07/13/23 10:44 AM
07/13/23 10:44 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The P5153843 casting is typically capable of well over 4.500 unless you're working with some kind of reject someone snuck home after hours or whatnot.
(This never, ever happens and never in my life have I heard of anyone doing such a thing LOL).
P5153843 was the common Dalton Foundry Iron Casting, machined for both wedge and hemi applications starting in about 2008.
Look for "DF" (with a backwards "D") foundry mark on the block to show it came from Dalton.
4.600+ is usually possible....it doesn't leave much to support a head gasket but can usually be done.
There were a few issues with those, but cylinder thickness was never one of them during my time there until 2013.
During my time, the ones that were sold with 4.500 bore were tested to ensure they would support it.
In practice, many did not trust our machine shop and insisted they personally machine the block.
None of the shops who started with a smaller bore and punched it out themselves ever complained about wall thickness.
(They complained about other things).
Always test the actual part you are going to use, to be sure.
Rich H.
Esse Quam Videri
