Is this an original A12 intake? #3158939
07/11/23 07:23 PM
07/11/23 07:23 PM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
Hi all, I recently bought this intake to use on a 'cuda street car. I was told it was an original A12 intake but after researching it a little, this does not have the slanted, or lazy "6" at the end of the part number. It also does not have the CH6B in the center of the drivers side. So, some say if the CH6B is missing it is original; and some say it must have the slanted "6" to be original. So what do you all think I have? It doesn't matter to me as I don't have an original A12 car, I'm just curious. I will be using it with an original factory set of 340 + 6 carbs on the 440.
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: Is this an original A12 intake? [Re: FJ6AAR] #3158993
07/11/23 11:10 PM
07/11/23 11:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
I think that may be one of the second batch casting that Mopar had Edelbrock make in the 1980s for over the counter sells confused
Re: Is this an original A12 intake? [Re: Cab_Burge] #3159063
07/12/23 10:01 AM
07/12/23 10:01 AM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
Ah, ok, so now I know, thanks.
Re: Is this an original A12 intake? [Re: FJ6AAR] #3159083
07/12/23 11:31 AM
07/12/23 11:31 AM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
A few years back I was looking at a manifold for my A12 road runner and I wasn't sure if it was a production line or over-the counter manifold (it had the standard 6, without the CH6B). Before purchasing I contacted Darrin (Big D A12) and he told me there were multiple runs of the Edelbrock intakes during the production of the A12 cars. Some had the wavey 6 (early production) and some had a standard 6 (later production), and both the wavey 6 and standard 6 are accepted as production line correct.
Some more info here.
Link
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Is this an original A12 intake? [Re: KWF340] #3159136
07/12/23 03:41 PM
07/12/23 03:41 PM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
Link
Thank you for posting that KWF340, it was a good read. So I might have an original after all.
Re: Is this an original A12 intake? [Re: FJ6AAR] #3159291
07/13/23 06:16 AM
07/13/23 06:16 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve got an original a12 Bee with the original manifold. It does NOT have the funny 6. I’ve got two more that I bought many years ago with original dated carbs. They look the same. My car was built about the middle of production. I do have one intake with the funny 6. It to supposedly an earlier cast intake. All the carb holes look the same and are not real clean cut like later over the counter intakes either. I bet yours is real.
Re: Is this an original A12 intake? [Re: fastmark] #3159341
07/13/23 09:22 AM
07/13/23 09:22 AM
Mattituck NY.
FJ6AAR Offline OP
FJ6AAR  Offline OP
Mattituck NY.
Hi Mark, thanks for the reply. That's nice to know it is what the guy I bought it from says it is.
