Re: 727 issues
[Re: Tech Instructor]
#3158107
07/08/23 07:35 PM
07/08/23 07:35 PM
Posts: 3,075 Michigan
A727Tflite
Fresh overhaul, reverse pattern manual valve body. Reverse works fine 1st and second are fine, when you go to shift to third it feels like it wants to lock up any thoughts? It air checked fine. Why the overhaul? What did you do inside during the overhaul? What did you replace during the overhaul? Sounds like the typical overlap - but why, all guesses until you provide more info. And, is this on the jack stands or driving the car?
Re: 727 issues
#3158174
07/09/23 03:32 AM
07/09/23 03:32 AM
Posts: 43,159 Bend,OR USA
Cab_Burge
Which brand manual valve body?
Re: 727 issues
#3158303
07/09/23 04:35 PM
07/09/23 04:35 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
when you go to shift to third it feels like it wants to lock up any thoughts? It air checked fine. Might need a restrictor orifice in the front clutch passage..
Re: 727 issues
[Re: John_Kunkel]
#3158364
07/09/23 09:16 PM
07/09/23 09:16 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
when you go to shift to third it feels like it wants to lock up any thoughts? It air checked fine. Might need a restrictor orifice in the front clutch passage.. John for OP's info, what size is the hole in the restrictor?
Re: 727 issues
[Re: TJP]
#3158526
07/10/23 01:32 PM
07/10/23 01:32 PM
John_Kunkel
Rio Linda, CA
when you go to shift to third it feels like it wants to lock up any thoughts? It air checked fine. Might need a restrictor orifice in the front clutch passage.. John for OP's info, what size is the hole in the restrictor? .090"-.120" usually works.
