727 issues #3158100
07/08/23 07:08 PM
07/08/23 07:08 PM
New England
Tech Instructor Offline OP
New England
Fresh overhaul, reverse pattern manual valve body. Reverse works fine 1st and second are fine, when you go to shift to third it feels like it wants to lock up any thoughts? It air checked fine.
Re: 727 issues [Re: Tech Instructor] #3158107
07/08/23 07:35 PM
07/08/23 07:35 PM
A727Tflite Offline
A727Tflite  Offline
Why the overhaul?
What did you do inside during the overhaul?
What did you replace during the overhaul?
Sounds like the typical overlap - but why, all guesses until you provide more info.
And, is this on the jack stands or driving the car?
Re: 727 issues [Re: Tech Instructor] #3158174
07/09/23 03:32 AM
07/09/23 03:32 AM
Which brand manual valve body?
Re: 727 issues [Re: Cab_Burge] #3158186
07/09/23 07:25 AM
07/09/23 07:25 AM
New England
New England
A&A valve body no low band apply
Re: 727 issues [Re: A727Tflite] #3158188
07/09/23 07:33 AM
07/09/23 07:33 AM
New England
New England
It was a core I purchased replaced clutches seals bands has billet front and rear servos from A& A . Front clutch has 5 clutches clearance was .082 rear clutch was .040 band adjustment front and rear was 72 ft lbs back off 2 turns. A& A valve body no low band apply.
Re: 727 issues [Re: A727Tflite] #3158189
07/09/23 07:34 AM
07/09/23 07:34 AM
New England
New England
This is driving the vehicle
Re: 727 issues [Re: Tech Instructor] #3158199
07/09/23 09:03 AM
07/09/23 09:03 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
How many servo springs in the front clutch? How is it under heavy accell? A little overlap on 2/3 may save the forward clutch under full power. Since it's all Rick's stuff call and ask him.
Doug
Re: 727 issues [Re: Tech Instructor] #3158303
07/09/23 04:35 PM
07/09/23 04:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Might need a restrictor orifice in the front clutch passage..
Re: 727 issues [Re: dvw] #3158336
07/09/23 06:52 PM
07/09/23 06:52 PM
New England
New England
Doug it is the early style servo with 2 springs
Re: 727 issues [Re: John_Kunkel] #3158364
07/09/23 09:16 PM
07/09/23 09:16 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
John for OP's info, what size is the hole in the restrictor? beer
Re: 727 issues [Re: TJP] #3158374
07/09/23 10:41 PM
07/09/23 10:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I don't think Rick uses a restrictor with his valve body's. That's why I would call and talk to him.
Doug
Re: 727 issues [Re: dvw] #3158465
07/10/23 10:05 AM
07/10/23 10:05 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Following closely.
As mine has a nasty shift to 3rd.
Mine will slam into 3rd gear on normal driving, almost like no springs in the front clutch is the best way I can describe it
If I lay into it and let it shift up itself, its not bad at all.
Plus mine will NOT downshift out of 3rd until darn near a full stop. Sucks when slowing down to make turns onto side streets or pulling up to a light and light turns green as an example, Ive got to where I pull it down to 2nd manually then shift back up once turn is completed
ps, Ive talked to the guy who built it 25 years ago and he isnt sure what was done to it back then
Re: 727 issues [Re: TJP] #3158526
07/10/23 01:32 PM
07/10/23 01:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
.090"-.120" usually works.
