What piston is this L2350 ? #3157003
07/04/23 07:12 PM
07/04/23 07:12 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
Just acquired a 1970 383 HP engine, pulled the 906 heads and found .030 over pistons with L2350 stamped in them. I checked google with no help. Anyone know what compression these pistons are claimed to be?
Re: What piston is this L2350 ? [Re: GODSCOUNTRY340] #3157035
07/04/23 09:20 PM
07/04/23 09:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Is that an old KB piston # ? Sounds familiar.
I looked on their site, and their part #s have changed, so the current 4.280-bore 383 part is UEM-KB210-030.
Re: What piston is this L2350 ? [Re: topside] #3157044
07/04/23 10:04 PM
07/04/23 10:04 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Nope. 50+ year old Trw/Speedpro forged Pistons.
Compression will likely be pretty low.
I might have an old Speedpro catalog in the shop. I will look tomorrow.
Edit: now that I think about it, might be a Trw/Speedpro cast stock replacement piston. Flat top, no valve notch, terrible compression ht. Might get 8:1 probably less.
Re: What piston is this L2350 ? [Re: GomangoCuda] #3157081
07/04/23 11:24 PM
07/04/23 11:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Aha - forgot about those old heavyweight TRW slugs - thanks.
Re: What piston is this L2350 ? [Re: topside] #3157119
07/05/23 08:57 AM
07/05/23 08:57 AM
Anyone know the compression height for the 383 magnum engine?
Re: What piston is this L2350 ? [Re: GODSCOUNTRY340] #3157134
07/05/23 10:08 AM
07/05/23 10:08 AM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
1.93 compression height
9.98 deck height
6.387 rod
3.387 stroke -1/2 is 1.69
9.98 - 6.387 - 1.69 = 1.89 so .042 above deck
Re: What piston is this L2350 ? [Re: cudaman1969] #3157165
07/05/23 11:38 AM
07/05/23 11:38 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
anyway number could have been mis-read? there is a 2315 383
Re: What piston is this L2350 ? [Re: GODSCOUNTRY340] #3157242
07/05/23 02:46 PM
07/05/23 02:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If they don't appear to be zero deck , the 2315 is about .020 in the hole , tallest replacement available , your compression is near 8.0 with a 906 not cut much..
Re: What piston is this L2350 ? [Re: cudaman1969] #3157245
07/05/23 02:51 PM
07/05/23 02:51 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
9.98 deck height
6.387 rod
I think you meant BELOW ???? ... that's even above the bloated NHRA spec of .021 above the deck , there wasn't a 383 built for production passenger cars or trucks with a positive deck height piston .
Some of your specs are incorrect , stroke for the 383 is 3.375 , 400 is 3.38
68-69 383 HP and 2bbl with a dish pistons are 1.932 , on a blueprint deck these pistons sit .0025 in the hole , that's the tallest B 383 CH piston.
Re: What piston is this L2350 ? [Re: GODSCOUNTRY340] #3157246
07/05/23 02:53 PM
07/05/23 02:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What year ?
68-69 are 1.932 I do not know if 70 is the same ?
Re: What piston is this L2350 ? [Re: lewtot184] #3157272
07/05/23 04:19 PM
07/05/23 04:19 PM
Not mis-read, definitely L2350.
Re: What piston is this L2350 ? [Re: GODSCOUNTRY340] #3157299
07/05/23 05:56 PM
07/05/23 05:56 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
9.98 deck height
6.387 rod
Stock stroke is actually 3.375”, and the correct rod length is 6.358”
Re: What piston is this L2350 ? [Re: JohnRR] #3157399
07/06/23 12:17 AM
07/06/23 12:17 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
"What piston is this" kinda sounds like the beginning to a drag racer's Christmas song.
Re: What piston is this L2350 ? [Re: JohnRR] #3157489
07/06/23 11:38 AM
07/06/23 11:38 AM
fredericksburg,va
fredericksburg,va
9.98 deck height
6.387 rod
68-69 383 HP and 2bbl with a dish pistons are 1.925 , on a blueprint deck these pistons sit .0025 in the hole , that's the tallest B 383 CH piston.
383 and 400 are the same, but I wrote some numbers down wrong, do the math. 1.925 plus rod length plus half the stroke (1.6875) then compare to deck height of 9.98. Still 9.9825 I went online to get those specs, I’ll re check them
Re: What piston is this L2350 ? [Re: fast68plymouth] #3157492
07/06/23 11:42 AM
07/06/23 11:42 AM
fredericksburg,va
fredericksburg,va
Originally Posted by fast68plymouth
Quote
9.98 deck height
6.387 rod
Brain fade, looking at the numbers AND still wrote down wrong! lol
Re: What piston is this L2350 ? [Re: cudaman1969] #3157495
07/06/23 11:54 AM
07/06/23 11:54 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
or... if you shave them about .050 and put them in a 426W block with a 4.15 crank and 6.76" rods you can make a low buck 478" RB
WIZE
In Car:
Re: What piston is this L2350 ? [Re: Streetwize] #3157579
07/06/23 03:44 PM
07/06/23 03:44 PM
GomangoCuda Offline
GomangoCuda  Offline
I found where Trw said that all L2000 series are forged and if it ends with an F it has floating pins.
Someone on FABO ID'd these as - 70-71 383 2 barrel (non HP) 1.863 compression height.
I have not yet been able to confirm this.
The L2315F Pistons that they still sell have 1.92 compression height.
Re: What piston is this L2350 ? [Re: cudaman1969] #3157609
07/06/23 04:44 PM
07/06/23 04:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
9.98 deck height
6.387 rod
My piston spec was wrong , corrected.
I'm pretty sure the 400 crank has that .005 longer stroke, it's a cast crank so it's not the same crank as the 383 .
Re: What piston is this L2350 ? [Re: GomangoCuda] #3157612
07/06/23 04:46 PM
07/06/23 04:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That is the tallest available aftermarket 383 piston , sold I believe as an NHRA replacement , it's as heavy as a stock cast piston except it's forged.
