4 Post Lift #3156885
07/04/23 02:12 PM
07/04/23 02:12 PM
Hunt Valley, Maryland
1fastrunner Offline OP
I will be getting a 4 Post Lift set up soon in my garage. The posts will not be secured to the floor so it can be moved. Should there be something between the post and the concrete floor? I see some people use a rubber pad in case of water or moisture, but does it really help?
Re: 4 Post Lift [Re: 1fastrunner] #3156887
07/04/23 02:14 PM
07/04/23 02:14 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
How bad is your water problem ?!?!?
Re: 4 Post Lift [Re: Stanton] #3156889
07/04/23 02:22 PM
07/04/23 02:22 PM
Don't really have a water problem, but do get some condensation on the floor when humidity is high.
Re: 4 Post Lift [Re: 1fastrunner] #3156904
07/04/23 02:48 PM
07/04/23 02:48 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
Mine are sitting right on the concrete floor and I have no issues. I have five of them.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: 4 Post Lift [Re: 1fastrunner] #3157140
07/05/23 10:34 AM
07/05/23 10:34 AM
Newburgh, NY
Old_Moparz Offline
Old_Moparz  Offline
Newburgh, NY
I've had 2 lifts set up since maybe 2005 or 2006, don't have anything between the base of the post & the concrete & all is fine.
If you have some type of expensive coating on the floor I can see wanting to place something in between so it doesn't chip.
Re: 4 Post Lift [Re: Old_Moparz] #3158080
07/08/23 05:38 PM
07/08/23 05:38 PM
I guess I won't over think it then. I was worried about the concrete getting condensation and having it get between the metal and the concrete.
Re: 4 Post Lift [Re: 1fastrunner] #3158280
07/09/23 02:28 PM
07/09/23 02:28 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
usually the bases are fairly think, I would be more concerned with not bolting them down. But it depends on the lift and where you live.
Re: 4 Post Lift [Re: Moparite] #3158371
07/09/23 10:00 PM
07/09/23 10:00 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
They are way more stable when bolted. But I used one for many years unbolted. beer
Re: 4 Post Lift [Re: 1fastrunner] #3158487
07/10/23 11:27 AM
07/10/23 11:27 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
I don't have anything between my post bottom plates and the concrete, and have never seen any rust spots or stains when I have moved my lift. I guess if you had to scoot it around or drag it on the concrete it would skin the bottoms and make it rust. I have the wheel kit with mine, and it will work the same way as yours. Enjoy your new lift, and using it for work is a LOT differen than laying on your back working! You will have to figure out how to work all over again....lol. up
