Tie rod ends and front end alignment #3155010
06/28/23 06:35 PM
06/28/23 06:35 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
What tie rod ends are best to use, Moog pro forged or?
I need a front end alignment, how to account for radial tires?
Re: Tie rod ends and front end alignment [Re: 340mouse] #3155020
06/28/23 07:16 PM
06/28/23 07:16 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I don't know what sort of mileage you put on your car but is it worth twice the price for Moog tie rod ends versus Mevotech ""original grade" units ??
Re: Tie rod ends and front end alignment [Re: Stanton] #3155034
06/28/23 07:57 PM
06/28/23 07:57 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
Well, I did order Moog parts, hoping they are still good quality, this is for my 68 Barracuda , just need to know the settings for alignment with radial tires.
Re: Tie rod ends and front end alignment [Re: 340mouse] #3155044
06/28/23 08:22 PM
06/28/23 08:22 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I would try for as much positive caster as you can. Most likely you will be at positive 2 to 3 degrees. Camber negative one to zero degrees and toe 1/16 to 1/8.
Re: Tie rod ends and front end alignment [Re: NITROUSN] #3155128
06/29/23 05:58 AM
06/29/23 05:58 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
These settings work well for daily driver. I'd plan on the offset bushings for the upper arms to ensure enough adjustment.
Angry white pureblood male
Re: Tie rod ends and front end alignment [Re: ruderunner] #3155294
06/29/23 03:20 PM
06/29/23 03:20 PM
moparx Offline
moparx  Offline
NITROUSN and Ruderunner both have good suggestions.
however, Moog's quality has been of question for at least the last 10-15 years, due to offshoring a lot of it's products.
in my opinion [only], Proforge is the [somewhat] go to manufacturer these days. i have used their products, and the ones i have used seem to be of better quality than today's Moog stuff, especially the longevity of the ball joint and tierod boots.
as to the Mevotech brand, i have also used a few of their products on my caravan [the "bus"], and they seem to be lasting and performing as they should. it should be noted the "bus" is not a drag strip terror, nor a canyon carver. biggrin
beer
Re: Tie rod ends and front end alignment [Re: moparx] #3155417
06/29/23 09:38 PM
06/29/23 09:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Might also check with RARE PARTS. They specialize in older vehicles and all there stuff is made in this country with a lifetime warranty beer
Re: Tie rod ends and front end alignment [Re: TJP] #3155885
07/01/23 11:40 AM
07/01/23 11:40 AM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
Well I did order Moog parts, it was pro forged I was trying to remember, it was the Skosh chart I was thinking of also, alignment tech says he has done lots of classic with radials so it will get done correct. Thanks
Re: Tie rod ends and front end alignment [Re: 340mouse] #3155979
07/01/23 03:52 PM
07/01/23 03:52 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Firmfeel has them in the bigger 11/16th's too. Not cheap but good quality is worth it IMO
https://firmfeel.com/products/11-16...ref_pid=8051464798526&pr_seq=uniform
Edit: you're looking for tie rod ends. I don't know if they have those.
Facts are stubborn things.
Re: Tie rod ends and front end alignment [Re: 340mouse] #3156702
07/03/23 09:18 PM
07/03/23 09:18 PM
Oakwood Ont Canada
340mouse Offline OP
340mouse  Offline OP
Oakwood Ont Canada
Thank goodness National Moparts is only 25 minutes away, while doing my brake conversion and front end work, I have been there 6 times for parts in the last 3 weeks, again up there again tomorrow.
