Re: '69 flashers - round or square ??
[Re: Stanton]
#3154516
06/26/23 09:59 PM
06/26/23 09:59 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Got one of each in my harness, which is original - round or square ?? Originals are all round, never saw the square ones until the 1990's.
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: NITROUSN]
#3154597
06/27/23 08:12 AM
06/27/23 08:12 AM
Posts: 8,867 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
So, some interesting replies ... 1) Sorry, I meant the relays - but everyone seems to call them flashers. 2) I have one of each square and round - turn and emerg 3) the mounting brackets accept both but fit the square ones better 4) Originals are all round, never saw the square ones until the 1990's. this is an interesting statement because I've owned the car since '73, never changed a relay and the car was mothballed in '85. So I'm pretty sure the square one is original.
[Re: Stanton]
#3154603
06/27/23 08:21 AM
06/27/23 08:21 AM
Posts: 18,409 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
So, some interesting replies ... 1) Sorry, I meant the relays - but everyone seems to call them flashers. 2) I have one of each square and round - turn and emerg 3) the mounting brackets accept both but fit the square ones better 4) Originals are all round, never saw the square ones until the 1990's. this is an interesting statement because I've owned the car since '73, never changed a relay and the car was mothballed in '85. So I'm pretty sure the square one is original. The factory parts manual calls them all Flashers. No mention of relay. 3 part numbers. 1-2932877 Most common turn and 4 way all car lines. 2-2932875 Says 2 lamp so it must be light duty. 3-2932876 Looks to be HD police and taxi. The mounting clip is one number 2770998
[Re: Stanton]
#3154701
06/27/23 02:18 PM
06/27/23 02:18 PM
NITROUSN
It was more of a curiosity question than anything else. Going to be using some LEDs so need to replace both with electronic. The new ones are all plastic with a ground wire - I assume the originals grounded through the case. OEM Flasher case does not need to be grounded.
[Re: NITROUSN]
#3154715
06/27/23 03:17 PM
06/27/23 03:17 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
OEM Flasher case does not need to be grounded. Interesting ... I just looked at the FSM wiring diagrams and sure enough ... no grounds. Just assumed 'cause some aftermarket units have ground pigtails that the originals were grounded.
[Re: Stanton]
#3154718
06/27/23 03:26 PM
06/27/23 03:26 PM
NITROUSN
OEM Flasher case does not need to be grounded. Interesting ... I just looked at the FSM wiring diagrams and sure enough ... no grounds. Just assumed 'cause some aftermarket units have ground pigtails that the originals were grounded. I do not recall ever seeing a flasher that needed a ground with incandescent lighting. LED lighting may be a completely different story.
[Re: NITROUSN]
#3155267
06/29/23 02:26 PM
06/29/23 02:26 PM
Posts: 19,364 north of coder
moparx
OEM Flasher case does not need to be grounded. Interesting ... I just looked at the FSM wiring diagrams and sure enough ... no grounds. Just assumed 'cause some aftermarket units have ground pigtails that the originals were grounded. I do not recall ever seeing a flasher that needed a ground with incandescent lighting. LED lighting may be a completely different story. even the somewhat later model K cars did not use a ground wire on the flasher can[s]. however, when the flasher cans were combined into one [square] unit in [or around] the 96ish [?] model year, using a multiple prong unit, i don't know if those are grounded or not. i never traced it to see.
[Re: Stanton]
#3155773
06/30/23 11:37 PM
06/30/23 11:37 PM
Posts: 10,201 Someplace you aren't
SomeCarGuy
I suppose it would be ok to use clear since the lens will tint it. That company suggested to use red on the brakes and I have to say it worked out. Seeing how much brighter it is let me know it’s worth it. I do carry the originals as spares after the set failed. I’m probably just too paranoid but I carry a trunk full of tools and parts so what was one more little box?
I want my fair share
[Re: SomeCarGuy]
#3155848
07/01/23 09:41 AM
07/01/23 09:41 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
but I carry a trunk full of tools and parts so what was one more little box? Murphy's law states: "A roadside breakdown will require the only tool and/or part not in your trunk"
