Re: who straightens steel rims/wheels
[Re: Cab_Burge]
#3153608
06/22/23 04:45 PM
06/22/23 04:45 PM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
I would return them to who you bought them from to have them fix them How much run out is there? mounted on some old 15 x 8 steel rims As asked, How much run out is there? Some shops think any run out is too much. If's not as big of a deal on 15 inch wheels unless it's really bad. The tire sidewall absorbs a lot.
[Re: SNK-EYZ]
#3153631
06/22/23 06:04 PM
06/22/23 06:04 PM
Posts: 20,613 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
These can be used to repair side to side wobbles in the bead seat area at home. https://youtu.be/ciYxlJlH6GAThere are more complex tools that use hydraulic jacks to straighten bent wheels if you look on YouTube.
[Re: Jim_Lusk]
#3153719
06/23/23 01:59 AM
06/23/23 01:59 AM
SNK-EYZ
A Red State
Honestly I think that the modern aluminum wheels might be easier to get fix than the old steel wheels.
Even if you take a chunk out of them, they simple weld the up machine them and re-powdercoat them.
[Re: SNK-EYZ]
#3153795
06/23/23 11:30 AM
06/23/23 11:30 AM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
Check in with a body shop. When I was working at one, we periodically sent wheels out for repair/straightening/refinish. One of the things insurance companies require to keep cost down.
Carl Kessel
[Re: mopars4ever]
#3153885
06/23/23 05:54 PM
06/23/23 05:54 PM
Posts: 4,725 Moved to N.E. Tennessee
GomangoCuda
Check with a local oval track shop. If that can't straighten steel wheels they probably know who can.
