Spark Plug Indexing Questions (updated with pic) #315308
05/11/09 07:52 PM
05/11/09 07:52 PM
BDW Online content OP
BDW  Online Content OP
The other post on distributor phasing got me thinking about spark plug indexing.
1) On a 340, which way should the gap opening face? Towards manifold?
2) I see both "flat" and "tapered" washers for this? What's the difference?
Thx
Re: Spark Plug Indexing Questions [Re: BDW] #315309
05/11/09 07:57 PM
05/11/09 07:57 PM
(1)I believe so (2) some plugs have tapered seats (for furd iirc), our plugs take flat washers
Re: Spark Plug Indexing Questions [Re: BDW] #315310
05/11/09 07:58 PM
05/11/09 07:58 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Stupid question but what is spark plug indexing?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Spark Plug Indexing Questions [Re: 70sixpkrt] #315311
05/11/09 08:05 PM
05/11/09 08:05 PM
runningman Offline
super street
runningman  Offline
super street
From what I understand indexing uses different sized washers so all of the plugs face the same direction when installed.
Re: Spark Plug Indexing Questions [Re: 70sixpkrt] #315312
05/11/09 08:18 PM
05/11/09 08:18 PM
Not a stupid question at all. It positions the plug when it's tightened so the ground strap is not in the way of the flame front spreading out into the chamber which makes a faster burn which needs less timing for the mixture to be spent at the perfect crank position for max power(less power wasted pushing the piston over the nose against the compression). You make a magic marker mark on the outside porcelean shell & use the right thickness washer so that when it's tightened that mark tells you that the ground strap that you now cannot see is not blocking the open part of the chamber
Re: Spark Plug Indexing Questions [Re: RapidRobert] #315313
05/11/09 08:58 PM
05/11/09 08:58 PM
70sixpkrt Offline
70sixpkrt  Offline
Thank you for the explanation. Now back to the question.
4-speed
3:54 Dana
Re: Spark Plug Indexing Questions [Re: 70sixpkrt] #315314
05/11/09 09:10 PM
05/11/09 09:10 PM
scratchnfotraction Offline
I have done it on just on a stock rebuild a few times and got a noticable gain in performance
I will add that its not just facing all the plugs the same way,it is faceing the plug the correct way for the cyl only
as in the valves move around in the head depending on the cyl
e,i,i,e,e,i,i,e looking at the exhast manny this is the valve arangement so to speak,so the plug would face the corrosponding direction
I have not done it in a while but,seems I allways faced the open part of the gap towards the cold intake charge
not real sure wich way now I thinks on it
but it what RR said
in shade tree lingo the plug gaps dont all face the front of the engine
they would face the correct direction per cyl
I will stop now...
I just wish I had wrote it down be fore I forgot
Re: Spark Plug Indexing Questions [Re: scratchnfotraction] #315315
05/11/09 09:12 PM
05/11/09 09:12 PM
oh and drilling the holes in the cap for ions to get out helps stop cross fire in the cap at high rpms
just not good for wet weather
and I only did that on chivy HEI dist on the BB mud truck
Re: Spark Plug Indexing Questions [Re: scratchnfotraction] #315316
05/11/09 10:51 PM
05/11/09 10:51 PM
Ok, so I need to point the spark plug gap opening towards the intake valve, and away from the exhaust valve on each cylinder?
Re: Spark Plug Indexing Questions [Re: BDW] #315317
05/11/09 11:01 PM
05/11/09 11:01 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
point the opening directly towards the center of the combustion area.
Re: Spark Plug Indexing Questions [Re: Dusted_Ya] #315318
05/12/09 01:36 AM
05/12/09 01:36 AM
MNobody Offline
MNobody  Offline
Which would be up, down,left or right?
Re: Spark Plug Indexing Questions [Re: MNobody] #315319
05/12/09 07:11 AM
05/12/09 07:11 AM
IMO,its best to set a head up for indexing while its off the block and you can see the comb chamber
then # the plug acordingly to the cyl
its free performance and a smoother running engine for some easy labor when puting one together
I have faced the plug opening towards the itake valve and have lined them all up in line with the little rectangle indent in the cc at the plug hole
but as stated...putting them in so the plug gap faces the expanding "wedge" makes for a complete burn and more leverage pushing down on the piston
thats why its called a "wedge head"
Re: Spark Plug Indexing Questions [Re: scratchnfotraction] #315320
05/12/09 07:34 PM
05/12/09 07:34 PM
Ok, which way should the spark plug gap opening point in this pic?
Re: Spark Plug Indexing Questions [Re: BDW] #315321
05/12/09 10:08 PM
05/12/09 10:08 PM
ok
I have lined them up in line with the recessed pad area off the plug hole
and I have lined them up with the open gap of plug facing the intake valve
need to know which way the shape of the of the cc on the heart shaped closed chamber heads swirl the intake charge around to to get it positioned in the right spot on the #302 heads, IMO
now I have also thought on putting the gap faceing into the cyl,so the gap faces the large side of the wedge to fire it from the small side and burn towards the big side maximizing the wedge effect of the wedge head
which IIRC is the right way for it to be facing
maybe someone else will correct me if I am wrong
Re: Spark Plug Indexing Questions [Re: scratchnfotraction] #315322
05/13/09 12:12 AM
05/13/09 12:12 AM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Up. Directly towards the manifold. Remember that the intake is still open (slightly) when the the spark ignites the F/A mix so the fire is swirling from the intake (hence the term swirl port). Just point it directly towards the center of the combustion chamber. That makes the bulk of the incoming fuel charge pass by the spark.
Re: Spark Plug Indexing Questions [Re: Dusted_Ya] #315323
05/13/09 07:35 AM
05/13/09 07:35 AM
Re: Spark Plug Indexing Questions [Re: scratchnfotraction] #315324
05/13/09 09:21 AM
05/13/09 09:21 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I could have sworn on the slant site they said face the opening towards the exhaust valve.
I know I smooth out the pocket where the plug is for flame travel towards the exhaust when I grind the chambers.
From what I have read indexing is worthless on the street, and mild race applications.
Cutting the ground strap might do something.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Spark Plug Indexing Questions [Re: Rug_Trucker] #315325
05/13/09 09:38 AM
05/13/09 09:38 AM
thats what I did & though I dont know how much it helped as it was on a new build but I felt good about doing it
Re: Spark Plug Indexing Questions [Re: Rug_Trucker] #315326
05/13/09 09:40 AM
05/13/09 09:40 AM
Az
Crizila Offline
Crizila  Offline
Az
Don't know if I'd call it worthless, but it is well over-blown! The intake charge sure isn't taking the same path in to the combustion chamber at idle as it is at 6,000rpm.
Fastest 300
Re: Spark Plug Indexing Questions [Re: RapidRobert] #315327
05/13/09 10:00 AM
05/13/09 10:00 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
OT What is this ground strap cutting that you speak of?
