Swapping Front Bearing Retainer - Large to Small #3152767
06/19/23 05:52 PM
06/19/23 05:52 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
So finding out I have a 68 833 4-speed and a 67 Bell housing. Long story short, I want to use this transmission and bell housing, but as you know the transmission has the larger front bearing retainer and the bell housing takes the smaller front bearing retainer. Can I buy a smaller front bearing retainer and swap it onto my 68 833? Thanks for help.
RS23L7 4-Speed
Re: Swapping Front Bearing Retainer - Large to Small [Re: Mopar_Mike] #3152770
06/19/23 06:04 PM
06/19/23 06:04 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
There area, at least, three front bearing retainer sizes and two bolt patterns. The smallest retainer will not bolt up to the largest bolt pattern, IIRC. So we need to know exactly what you have.
http://www.brewersperformance.com/products.php?cat=82
Re: Swapping Front Bearing Retainer - Large to Small [Re: Mopar_Mike] #3152771
06/19/23 06:18 PM
06/19/23 06:18 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
You would need a different bell housing or have yours machined larger.
(as mentioned, the bearing retainers will not swap)
Re: Swapping Front Bearing Retainer - Large to Small [Re: Sniper] #3152773
06/19/23 06:25 PM
06/19/23 06:25 PM
Danville, NH
Danville, NH
C97621 is on the 68 transmission. It is an 18 spline overdrive 4-speed built by Jamie Passon 10 or so years ago. I want to use it in my 67 440 GTX but I would like to keep the factory cast iron bell housing.
RS23L7 4-Speed
Re: Swapping Front Bearing Retainer - Large to Small [Re: Mopar_Mike] #3152775
06/19/23 06:27 PM
06/19/23 06:27 PM
Danville, NH
Danville, NH
Thanks all..
RS23L7 4-Speed
Re: Swapping Front Bearing Retainer - Large to Small [Re: Mopar_Mike] #3152783
06/19/23 07:02 PM
06/19/23 07:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Talk to the guys at Brewers, maybe they can suggest a compromise.
Re: Swapping Front Bearing Retainer - Large to Small [Re: Stanton] #3152871
06/19/23 10:32 PM
06/19/23 10:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Swapping Front Bearing Retainer - Large to Small [Re: Mopar_Mike] #3152907
06/20/23 03:06 AM
06/20/23 03:06 AM
NP I think made both size front bearing retainers for both the 23 spline and 18 spline tranny depending on what year the tranny was going into, I THINK confused scope
I've ran into that years ago doing some work on a customer's 4 speed car swapping the stock bell housing for a scatter shield so he could race it at some tracks in SO CA years ago scope
Another option is to use the adapter ring from the scatter shield so you can use the smaller front bearing retainer in the larger hole bell housings work scope wrench up
Re: Swapping Front Bearing Retainer - Large to Small [Re: Stanton] #3152920
06/20/23 06:25 AM
06/20/23 06:25 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
If you have the small 307 front bearing then you should be able to buy a retainer that is the smaller size to fit the 307 and the 67 small hole bell housing. Only the 440/426 cases had the big 308 bearing. Check with brewers.
Re: Swapping Front Bearing Retainer - Large to Small [Re: fastmark] #3152923
06/20/23 07:04 AM
06/20/23 07:04 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Guys? He said;
Quote
There is not an adapter to go from large bearing retainer to small. wave
Re: Swapping Front Bearing Retainer - Large to Small [Re: Alaskan_TA] #3153015
06/20/23 12:01 PM
06/20/23 12:01 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
That's what I did with mine.
I too have a 1968 23 spline 4 speed meant to go behind a 383 engine.
I'm using it behind my 360 engine.
The retainer that came with the 4 speed is too big for my bellhousing.
I was going to open up the opening in the bellhousing, but hesitated.
I went online and found the correct one thru Brewers.
Bearing Retainer(18).jpgBearing Retainer (19).jpgBearing Retainer (1).jpgBearing Retainer (2).jpg
Re: Swapping Front Bearing Retainer - Large to Small [Re: 76Beeper] #3153060
06/20/23 02:09 PM
06/20/23 02:09 PM
moparx Offline
moparx  Offline
did you need to change the bearing as well ?
i know virtually nothing about 4 speeds. just wanting to learn, so bear with me, please.
beer
Re: Swapping Front Bearing Retainer - Large to Small [Re: moparx] #3153066
06/20/23 02:44 PM
06/20/23 02:44 PM
Danville, NH
Danville, NH
Just emailed Brewers about any possible solutions.. but, if I decided to go with the making the bell housing hole bigger, what would be involved. Could any engine builder/machine shop do it? Is it costly? would I ever be able to use the original smaller retainer transmission again?
RS23L7 4-Speed
Re: Swapping Front Bearing Retainer - Large to Small [Re: Mopar_Mike] #3153118
06/20/23 06:24 PM
06/20/23 06:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Making the bellhousing hole bigger would require I believe also relocating the the clutch fork pivot over as it is very close the the hole, this may also require a different fork to go with that? I would have a machine shop do it , costly , probably but you got it ... devil .
You would be able to use your other transmission with just a bearing retainer swap or an adapter ring to fill the hole back in.
The big block A body uses the same bell, I want run a hemi 4 speed in my dart but didn't want to modify my original bellhousing so after doing some comparing it looks like the 70/up 130 tooth BB alum bellhousing is a copy of the 67 cast iron with a larger bearing retainer hole.
The other thing you could do is put the guts of your trans into a small bearing case, it's not very hard to do, though the OD trans went to the 308 front bearing for a reason?
Re: Swapping Front Bearing Retainer - Large to Small [Re: moparx] #3153120
06/20/23 06:24 PM
06/20/23 06:24 PM
Originally Posted by moparx
did you need to change the bearing as well ?beer
No need to remove the input shaft and change the front bearing, remove the large bearing retainer and install the small one with a new inner seal and gasket scopewrench up
Re: Swapping Front Bearing Retainer - Large to Small [Re: Cab_Burge] #3153175
06/20/23 08:40 PM
06/20/23 08:40 PM
nowhere
nowhere
I believe that there is no small retainer (4.354" outside diameter) that uses the large bolt pattern (4.16"). I don't know which the OP has, which is why I linked to Brewer's as the dimensions were there for his use.
Re: Swapping Front Bearing Retainer - Large to Small [Re: Sniper] #3153186
06/20/23 09:27 PM
06/20/23 09:27 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Quote
You DO NOT want to do that.
Re: Swapping Front Bearing Retainer - Large to Small [Re: Stanton] #3153254
06/21/23 08:09 AM
06/21/23 08:09 AM
VA
dragon slayer Offline
VA
You have a 68 HEMI transmission. The C97621 is the large diameter 4.805"dia, 308 bearing with 4.16" hole pattern. The bearing and hole pattern are on your transmission so you can't change that without swapping case. Your trying to stick this in a Bell House that need a 4.354 diameter retainer.
So messing with a BH is problematic. Your alternative is to get the over drive retainer that has 5.125 dia, 308 bearing and 4.16 hole pattern. Turn it down to 4.354. This would also be pretty close to cutting into the holes of the retainer. This is much easier to do. BUT since your a 18sp, they will also have to put a sleeve on the tube the throwout bearing rides on and bore the diameter out. Lot of work, but I think better then working on BH. Frankly I would look for the 68 BH.
I have turned a OD retainer for a 308 23 spline to the large hole 4.805. That was easy and worked. You really may be stuck with changing Case or BH.
Re: Swapping Front Bearing Retainer - Large to Small [Re: dragon slayer] #3153271
06/21/23 08:50 AM
06/21/23 08:50 AM
Danville, NH
Danville, NH
Seems like a lot of work and cost to try to modify what I have to work the way I want it to. Brewers also mentioned just switch the bell housing. Since it is the wrong (numbers wise) transmission anyways. Thanks again for everyone's help.
RS23L7 4-Speed
Re: Swapping Front Bearing Retainer - Large to Small [Re: Mopar_Mike] #3153447
06/21/23 10:06 PM
06/21/23 10:06 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Is there enough meat on an 18 spline retainer to turn it down to the size your bellhousing is?
As you said, your trans isn't the "correct" one anyway so if you can source a compatible bellhousing, that's probably the easy button solution provided it's compatible with your clutch and flywheel.
Most of the car show "experts" will be too busy yammering on about their uncle's factory 383 hemi 62 Valiant to notice anyway. thumbs
Kevin
