727 puking fluid during a run #3151171
06/13/23 12:20 PM
06/13/23 12:20 PM
an8sec70cuda Offline OP
So I noticed my 727 is puking a little fluid out of the vent during a run. It does have a transbrake (Turbo Action pro brake) and the vent is relocated to the top rear of the case at about the 11:00 position when looking at it from the rear.
Why is it doing this? Is it overfull?
Should I install a breather tank? Just remove the vent and put a different fitting in the case plumbed to a catch can? Should I do it in -4an or -6an line?
Any particular catch can yall would recommend?
I found this one earlier...
https://allstarperformance.com/mini-breather-tank-panel-mount-all36142/
Any other suggestions?
Thanks beer
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 puking fluid during a runansbrake and has the vent reloc [Re: an8sec70cuda] #3151175
06/13/23 12:25 PM
06/13/23 12:25 PM
Cab_Burge Online work
Cab_Burge  Online Work
What is the fluid level warm or hot in neutral on the dipstick?
I like to run my fluid level in 727s with a deep tranny pan at the add mark, warm or hot scopeup
Re: 727 puking fluid during a runansbrake and has the vent reloc [Re: Cab_Burge] #3151180
06/13/23 12:28 PM
06/13/23 12:28 PM
Cab...it's either at the full mark or just a hair below it. Maybe I should drop 1/2 a quart out and try again?
CHIP
Re: 727 puking fluid during a runansbrake and has the vent reloc [Re: an8sec70cuda] #3151181
06/13/23 12:35 PM
06/13/23 12:35 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Chip, I HEARD, never experienced, that some 727 do that, some don't and there is no explanation to this. Once again, that is what I heard. Was also told to get with Cope Transmissions for the "fix". Hope that helps. wave
Re: 727 puking fluid during a runansbrake and has the vent reloc [Re: an8sec70cuda] #3151184
06/13/23 12:41 PM
06/13/23 12:41 PM
If you have a deep tranny pan I would drop it one quart to make it read at the add mark when warm or hot up twocents
Do you run a trans temp gauge? I added one and found out that my drag cars with 727 would never get above 160F when foot brake racing it, same thing on my last Cuda with a Powerglide with a brake, never got above got above 200 F when hot lapping it using the brake at WOT for whatever time it was at WOT based on top bulb bracket racing shruggy confused
Re: 727 puking fluid during a run [Re: an8sec70cuda] #3151198
06/13/23 01:09 PM
06/13/23 01:09 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I'd remove the 727, and install a clutch pedal. Problem solved.
69 GTX 68 Road Runner
Re: 727 puking fluid during a run [Re: JERICOGTX] #3151204
06/13/23 01:35 PM
06/13/23 01:35 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
That and a new drive shaft :-)
Re: 727 puking fluid during a run [Re: an8sec70cuda] #3151209
06/13/23 01:39 PM
06/13/23 01:39 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
Which dip stick are you using? When I tired to use an aftermarket one years ago it wasn't marked the same as my stock one. My guess is the trans is just a tad overfilled. I have no experience with a trans brake though as I'm a footbraker. I have a trans temp gauge in my deep pan. After going some rounds this weekend my trans was 190 at the hottest I seen in the staging lanes, can't say I really ever look at it after a run, just before I make a run but I know transbrakes can build heat quickly.
Re: 727 puking fluid during a run [Re: DusterKid] #3151217
06/13/23 02:04 PM
06/13/23 02:04 PM
Cab...it does have a deep pan. I'll try removing some fluid and see if that helps. No trans temp gauge.
Jerico...I'm tearing up enough stuff as it is. No need to make it worse, lol.
Dusterkid...Lokar dipstick. I know it might not read perfect, but I tend to add fluid and then try the trans to see how it engages when I'm refilling it. Not relying only on the dipstick.
I wasn't on the brake long at all on any of my three passes so I don't think heat was a factor in the trans puking.
CHIP
Re: 727 puking fluid during a run [Re: an8sec70cuda] #3151218
06/13/23 02:05 PM
06/13/23 02:05 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
You eventually run out of weak links...
Re: 727 puking fluid during a run [Re: JERICOGTX] #3151242
06/13/23 03:01 PM
06/13/23 03:01 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
what i have sean before is that remember that cooler return line comes in just below that vent so at high rpms fluid can splash out of vent. on all the race cars we do we always run a hose from fent to puke tank.
JAKES AUTOMOTIVE
Re: 727 puking fluid during a run [Re: an8sec70cuda] #3151244
06/13/23 03:07 PM
06/13/23 03:07 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
How is your converter acting? Are you running more RPM on the big end? I have seen them puke a little when the converter slips too much. Had it happen to me. Shift light started staying on after I shifted, and it was puking a little every run. Pulled trans apart you could still see the writing on the clutches, converter fixed it.
Re: 727 puking fluid during a run [Re: an8sec70cuda] #3151246
06/13/23 03:12 PM
06/13/23 03:12 PM
montana
BANDIT Offline
BANDIT  Offline
montana
\On my cars, all have a puke tank. The one you have in your link will work fine. Instead of AN hose, I run 1/4 in plastic air line, like big trucks have on air brakes, along with the associated push style connectors. The NAPA store here has those pieces, if not, any truck parts store should have them. Cheaper and easier than using AN stuff, and holds up fine. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: 727 puking fluid during a run [Re: BANDIT] #3151259
06/13/23 04:20 PM
06/13/23 04:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My proflite has a puke tank, well more of a recovery tank as it feeds from the bottom so anything that does get in it just goes back in to the trans later. It is from heat with heat the fluid expands a fair amount. As suggested drop the level a tad and for peace of mind use a puke or recovery tank. As for converter slip causing it sure that puts more heat in the fluid. Which will cause it to expand.
FWIW we use these. I use a vent on top and the line feeds from the bottom. Airlines work just fine with pushlock fittings.
https://quartermax.com/transmission-overflow-kit/
Re: 727 puking fluid during a runansbrake and has the vent reloc [Re: an8sec70cuda] #3151262
06/13/23 04:35 PM
06/13/23 04:35 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Chip , I had this issue with one of my 727's , not sure why the other did not , but , As with all other replies , yes have deep pan & stock dip stick . I had placed a plastic bottle on vent tube , just because I wanted to know just how much it was spitting out . In my case I found it was over filled . Having talked to many folks on trans oil level it was the general consensus to not fill over where pan bolts to trans . I also installed an aftermarket dip stick which was marked also at pan gasket line . No more pushing out fluid . My plastic bottle is still on there but no fluid inside .
Re: 727 puking fluid during a run [Re: an8sec70cuda] #3151266
06/13/23 04:41 PM
06/13/23 04:41 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
I would check dipstick calibration. I cut out a section of the webbing under the rear support so oil can’t fill up in that area, also I plugged the oil feed hole in the end of the park paw. Stopped the small amount oil out my vent.
Re: 727 puking fluid during a run [Re: rickraw] #3151269
06/13/23 05:06 PM
06/13/23 05:06 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
A word of advice if using any type of threaded fittings in that hole… there is a very minimal amount of material surrounding the hole. threading it to a npt should be done with extreme care. Installing the fitting can easily crack the material so “thread lightly”
Re: 727 puking fluid during a run [Re: TRENDZ] #3151278
06/13/23 05:47 PM
06/13/23 05:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Mine barfed on the highway one time and I never figured out why. It actually caused a small fire that extinguished itself rather quickly thankfully. It was still the factory vent location at that point, the next time the trans was out I moved it to rear. Never been an issue since that one time.
68 Barracuda Formula S 340
Re: 727 puking fluid during a run [Re: TRENDZ] #3151288
06/13/23 06:08 PM
06/13/23 06:08 PM
Ambridge, Pa.
Ambridge, Pa.
Npt is not needed, I just tapped the hole for fine thread ( about 1/8” deep) green loctite screw and cut off the excess, never a problem leaking or coming apart.
Re: 727 puking fluid during a run [Re: rickraw] #3151296
06/13/23 06:46 PM
06/13/23 06:46 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have a Jegs trans puke tank. I call it Bruce. It's good in drag applications.
