Page 5 of 7 1 2 3 4 5 6 7
Re: headers glowing red at idle [Re: MarkZ] #3150150
06/10/23 06:13 AM
06/10/23 06:13 AM
st.louis,mo.
dart games Offline OP
st.louis,mo.
so this is the engine and specs i bought from a local mopar person.cant find any info on the cam.email comp cams.heard nothing.that customer service sucks,thumper offers no turning advise.that customer service sucks.moal of the story.never buy a engine unless it wasw dynoed or you can here it running.if you do.spend a few hundred bucks and tear it down and check someones work.......................... - 400 Cold Weather 230 Block (.030
overbore) - This is strongest Mopar
production block, very hard to come by
as they only made them in the summer
of 1971.
- Molnar Forged Crank and Rods
- Ross Pistons (10.5 to 1 Compression for
pump gas)
- TRICK FLOW 270 HEADS!! (very hard
to find right now) flow 353 cfm on the
intake at .700 inch lift.
- Comp Solid Roller Cam and lifters( see
picture for specs)
- Smith Push Rods
- Harland Sharp Roller Rocker Arm (1.5
ratio)
- Indy Max Wedge Port Intake (4500
flange)
- ATI Harmonic Balancer
- 1020 Holley Dominiator Carb Built by
Dominic at Thumper Carbs (Dominic is
know for building Dominator's that run
well on the street and strip)
- BLP Racing Fuel Log
- MSD Billet Distributor
- Taylor 9MM Fire Power Spark Plug
Wires
- All new or rebuilt front accessories (
has a single serpentine belt running all
accessories including Power Steering
Pump)
- Electric Water Pump
- Hooker Super Comp Headers (For 69
Mopar B Body Chasis). These are
uncoated/painted black.
- Milodon Oil Pan
341918564_6565295870187502_2880771962167508873_n.jpg339522009_6032546533528103_4988661725278437091_n.jpg322720354_5596944647077519_1388361090330914218_n.jpg
Re: headers glowing red at idle [Re: dart games] #3150233
06/10/23 01:26 PM
06/10/23 01:26 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
What's gonna happen to the engine? What stroke is it? I've read the whole thread, sorry if I missed it, but was the TDC mark verified? Amount of advance verified? Good luck, in any caseup
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: headers glowing red at idle [Re: metallicareload] #3150273
06/10/23 04:39 PM
06/10/23 04:39 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
You need more info on the cam than this?
Re: headers glowing red at idle [Re: fast68plymouth] #3150281
06/10/23 05:14 PM
06/10/23 05:14 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What do you want for the engine? Also never saw what the car was.
Re: headers glowing red at idle [Re: dart games] #3150282
06/10/23 05:14 PM
06/10/23 05:14 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
You have a Private Message.
Re: headers glowing red at idle [Re: dart games] #3150300
06/10/23 06:52 PM
06/10/23 06:52 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I find it hard to believe that Thumper won't help after you bought a carb from him.
He helped me before I ever bought any thing.He is one of the better vendors here.
I had an issue similar to yours just opposite symptoms.Its hard solving tuning issues on a web board. Can you call someone or
bring it to someone for 2nd set of eyes?
Whats funny the person who actually figured out my issue was BigDad's favorite person...lol
Re: headers glowing red at idle [Re: dart games] #3150305
06/10/23 07:18 PM
06/10/23 07:18 PM
alabama, usa
burks340 Offline
burks340  Offline
alabama, usa
i know a guy had an all aluminum indy engine in dragster . he couldnt get it to idle pulled the heads off took them to reputable machine shop had a pressure check ran well the heads didnt pass the pressure check for roller springs he installed heard back on engine and got it to idle . it may not be your problem but run a compression check on each cylinder with plugs out all cylinders should be within 10 lbs of eachother
Re: headers glowing red at idle [Re: fast68plymouth] #3150313
06/10/23 07:53 PM
06/10/23 07:53 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted by fast68plymouth
Quote
Why? Already determined it’s the carbs fault wink
Re: headers glowing red at idle [Re: fast68plymouth] #3150409
06/11/23 09:13 AM
06/11/23 09:13 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Quote
What is missing? just curious, trying to learn.
I see the lobes, the duration, the lift, the separation, and the intake centerline.
Re: headers glowing red at idle [Re: B1MAXX] #3150412
06/11/23 09:32 AM
06/11/23 09:32 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Only thing missing are the timing events.
Re: headers glowing red at idle [Re: rickraw] #3150416
06/11/23 10:10 AM
06/11/23 10:10 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Aren't those discernible?
Re: headers glowing red at idle [Re: B1MAXX] #3150465
06/11/23 11:34 AM
06/11/23 11:34 AM
So. Burlington, Vt.
So. Burlington, Vt.
Indeed they are.
@.050:
21.5/61.5 - intake
64.5/24.5 - exhaust
If installed with the intake c/l as per the tag.
What’s actually missing is the recommended lash spec.
But anything between .018”-.026” would be close enough to rule that out as being the problem.
Re: headers glowing red at idle [Re: fast68plymouth] #3150485
06/11/23 12:30 PM
06/11/23 12:30 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Got it on the lash. up I just put in a Howards solid and was surprised to see .016 on the card, so I understand.
Re: headers glowing red at idle [Re: B1MAXX] #3150555
06/11/23 05:38 PM
06/11/23 05:38 PM
st.louis,mo.
st.louis,mo.
PROBLEM FIX. AFTER 8 HOURS ON IT TODAY.today i had no lawn service to do and no car show or cruishing,raining day so thought ill fiquire this crap out.,after going back into the timing set.took it off of 4 degree advance put it on tdc.put it back together same.bump timing up to 40,same.took off carb.drill holes in throttle plates,same last ditch effort as nothing else worked.i swapped the idle bleeds and it worked .set idle and reset timing.this time i blame thumper for that one.will keep car and see what it does.will take down ads.after 3 weeks it was something so simple as the air bleeds was put in wrong
Re: headers glowing red at idle [Re: dart games] #3150556
06/11/23 05:40 PM
06/11/23 05:40 PM
tboomer Offline
tboomer  Offline
I have been following this...Great find! up
Re: headers glowing red at idle [Re: tboomer] #3150596
06/11/23 07:12 PM
06/11/23 07:12 PM
Mo.
racerx Offline
racerx  Offline
Mo.
X2 up
I see you out of st.Louis .what track you race at?
Re: headers glowing red at idle [Re: dart games] #3150693
06/12/23 12:52 AM
06/12/23 12:52 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
Still not Dom's fault. Glad you got it figured out. Now go beat on it.
America First!
Re: headers glowing red at idle [Re: carnut68] #3150715
06/12/23 06:16 AM
06/12/23 06:16 AM
st.louis,mo.
st.louis,mo.
car nut.thumper built the carb.why was the bleeds put in the wrong place.the motor was built correctly.next thing is should i put everything back the way it was.i didnt mention during the week i change the valve lash from 15 int,20 exhaust to 25 straight up.and that didnt fix it.but i might go change that.i dont feel i should go back in and change it back to 4 degree advanced.all that does is change the power band.should i put the power valve back in carb.i did plug it.do i put rivets in the throttle blades where i drilled them.it idles ok
Re: headers glowing red at idle [Re: dart games] #3150727
06/12/23 07:56 AM
06/12/23 07:56 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Congrats on fixing it! So it was predominantly spark advance. Did you buy the carb from Thumper?
Re: headers glowing red at idle [Re: HardcoreB] #3150728
06/12/23 08:08 AM
06/12/23 08:08 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
.025 hot is about as loose as I would go. If the jetting was with a power valve you better put it back in, or you'll be very lean up top.
