Re: headers glowing red at idle
[Re: metallicareload]
#3150273
06/10/23 04:39 PM
06/10/23 04:39 PM
fast68plymouth
So. Burlington, Vt.
cant find any info on the cam. You need more info on the cam than this?
[Re: fast68plymouth]
#3150281
06/10/23 05:14 PM
06/10/23 05:14 PM
Posts: 19,385 Las Vegas
Al_Alguire
Las Vegas
What do you want for the engine? Also never saw what the car was.
#3150313
06/10/23 07:53 PM
06/10/23 07:53 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
cant find any info on the cam. You need more info on the cam than this? Why? Already determined it’s the carbs fault ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
#3150409
06/11/23 09:13 AM
06/11/23 09:13 AM
Posts: 2,013 Apollo, PA.
B1MAXX
Apollo, PA.
cant find any info on the cam. You need more info on the cam than this? What is missing? just curious, trying to learn. I see the lobes, the duration, the lift, the separation, and the intake centerline.
[Re: B1MAXX]
#3150465
06/11/23 11:34 AM
06/11/23 11:34 AM
fast68plymouth
So. Burlington, Vt.
Aren't those discernible? Indeed they are. @.050: 21.5/61.5 - intake 64.5/24.5 - exhaust If installed with the intake c/l as per the tag. What’s actually missing is the recommended lash spec. But anything between .018”-.026” would be close enough to rule that out as being the problem.
[Re: tboomer]
#3150596
06/11/23 07:12 PM
06/11/23 07:12 PM
Posts: 4,078 Mo.
racerx
Mo.
I have been following this...Great find! X2 ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I see you out of st.Louis .what track you race at?
[Re: dart games]
#3150693
06/12/23 12:52 AM
06/12/23 12:52 AM
Posts: 3,254 Md.
carnut68
Md.
PROBLEM FIX. AFTER 8 HOURS ON IT TODAY.today i had no lawn service to do and no car show or cruishing,raining day so thought ill fiquire this crap out.,after going back into the timing set.took it off of 4 degree advance put it on tdc.put it back together same.bump timing up to 40,same.took off carb.drill holes in throttle plates,same last ditch effort as nothing else worked.i swapped the idle bleeds and it worked .set idle and reset timing.this time i blame thumper for that one.will keep car and see what it does.will take down ads.after 3 weeks it was something so simple as the air bleeds was put in wrong Still not Dom's fault. Glad you got it figured out. Now go beat on it.
America First!
[Re: carnut68]
#3150715
06/12/23 06:16 AM
06/12/23 06:16 AM
Posts: 682 st.louis,mo.
dart games
st.louis,mo.
car nut.thumper built the carb.why was the bleeds put in the wrong place.the motor was built correctly.next thing is should i put everything back the way it was.i didnt mention during the week i change the valve lash from 15 int,20 exhaust to 25 straight up.and that didnt fix it.but i might go change that.i dont feel i should go back in and change it back to 4 degree advanced.all that does is change the power band.should i put the power valve back in carb.i did plug it.do i put rivets in the throttle blades where i drilled them.it idles ok
