Stripe replacement #3149183
06/06/23 06:23 PM
06/06/23 06:23 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
The trunk stripes have been on my 72’ Swinger for around 15yrs, starting to unglue/lift in a few places, also just brittle from the sun. I’d like to replace them. Any tips for removing the old ones without paint damage? Also who is making a good replacement set? Thanks.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Stripe replacement [Re: busboy] #3149189
06/06/23 06:57 PM
06/06/23 06:57 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Hair dryer, or heat gun used carefully, to sotfen the adhesive up. Pull/roll the vinyl off slowly back over top of itself instead of straight up and off like you would with a band-aid.
New ones I would start here. https://www.performancecargraphics.com/Stripes_Lettering.htm
Re: Stripe replacement [Re: Neil] #3149245
06/06/23 10:32 PM
06/06/23 10:32 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Re: Stripe replacement [Re: Neil] #3149367
06/07/23 12:10 PM
06/07/23 12:10 PM
busboy Offline OP
busboy  Offline OP
Thanks, mild heat sounds good, was not keen on any chemicals to risk damage to the paint! What would be best to remove any residual addhesive?
Re: Stripe replacement [Re: busboy] #3149383
06/07/23 12:55 PM
06/07/23 12:55 PM
moparx Offline
moparx  Offline
3M makes an adhesive remover that works pretty good.
there may be other brands out there that work better, but the 3M stuff is the only brand i have used a few times.
then there is that stuff called "goo gone". that works pretty good for common sticky labels like racing decals.
beer
Re: Stripe replacement [Re: moparx] #3149528
06/07/23 08:33 PM
06/07/23 08:33 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Should be very little glue residue I'd think. Autobody wax and grease remover is safe for paint and should take care of it.
Before landing the new decal use a tack rag to clean the surface. Even the smallest dust/lint particles can telegraph thru the vinyl and once it's down your kinda stuck with them.
Re: Stripe replacement [Re: Neil] #3149546
06/07/23 09:22 PM
06/07/23 09:22 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I've used the 3M stuff for years on multiple customers cars with no issue. Still it would be best to test first in an inconspicuous area . may want to rub the test area as you would the stripe area checking every so often. beer
Re: Stripe replacement [Re: busboy] #3149804
06/08/23 07:46 PM
06/08/23 07:46 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Moparx is right, goo-gone is very good. WD40 also safe and effective
Facts are stubborn things.
