Best dash speaker for b body #3148107
06/02/23 07:51 AM
06/02/23 07:51 AM
Someplace you aren't
SomeCarGuy Online content OP
SomeCarGuy  Online Content OP
The AM radio is out for a rebuild and while I have the under dash apart to fix a laundry list of things, I figure changing the speaker is a now or never thing. the radio never played in this car, I found a blown fuse and it came on enough to think the caps are blown, then stopped doing even that. Not sure if this speaker is any good or not.
I’ll be adding an FM convertor I picked up off eBay. I want clear sound and have no interest in a loud stereo, thumping, etc. I found these two, I’m intrigued by the first one because it seems to offer an updated sound.
anybody use this one?
https://www.vintagecarradio.com/spe...profile-speaker-dual-voice-coil-speaker/
This one seems more like a stock replacement
https://www.smelectrotech.com/produ...sbp=false&q=false&category_id=10
I want my fair share
Re: Best dash speaker for b body [Re: SomeCarGuy] #3148145
06/02/23 10:21 AM
06/02/23 10:21 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
While both will work the Dual Voice Coil speaker is overkill in your application as its made to handle some power and produce hi fidelity (1970s term!) sound. Your system is neither powerful or hi fi- no insult intended. I would choose based on quality and being name brands are not what they used to be- some are not familiar- you'll have to read reviews and research those two speakers you have posted.
Keep old mopars alive.
Re: Best dash speaker for b body [Re: SomeCarGuy] #3148220
06/02/23 02:35 PM
06/02/23 02:35 PM
i used one like your first one listed on a build years ago that had a woofer and a small tweeter in it also, it work good. up
Re: Best dash speaker for b body [Re: 2boltmain] #3148221
06/02/23 02:36 PM
06/02/23 02:36 PM
[align:center][/align]I found some places showing the dual coil doesn’t work with oem 8-10 ohms. I called the place saying it does and they told me it does not.
Re: Best dash speaker for b body [Re: SomeCarGuy] #3148223
06/02/23 02:40 PM
06/02/23 02:40 PM
You can shop around and find them in 4 ohms speakers like them, or you use to be able to buy them shruggy
Re: Best dash speaker for b body [Re: Cab_Burge] #3148404
06/03/23 01:46 PM
06/03/23 01:46 PM
moparx Offline
moparx  Offline
there used to be a place called "crutchfeild" that was pretty good at sound systems, their techs knew their stuff, and were very friendly to work with.
i don't know if that place is still around or not. shruggy
beer
Re: Best dash speaker for b body [Re: moparx] #3148477
06/03/23 07:12 PM
06/03/23 07:12 PM
Kirkland, Washington
Pacnorthcuda Offline
beer
Very much alive and well.
https://www.crutchfield.com/
Re: Best dash speaker for b body [Re: Pacnorthcuda] #3148488
06/03/23 08:21 PM
06/03/23 08:21 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I installed the dual coil speaker last year in an E-body dash. Thankfully I had the dash out of the car.
There was not enough clearance o the backside to drop the speaker in. I had to do some mods to the speaker chassis and mounting hardware to get it to fit without having to cut into the dash frame (others have).
My original radio was gone so I replaced it with one from classic car stereo that looks OEM, but is modern internally.
That took car of the ohm issue.
https://www.classiccarstereos.com/1970-71-mopar-e-body-radio-chrome-buttons.html
Re: Best dash speaker for b body [Re: Pacnorthcuda] #3148502
06/03/23 09:37 PM
06/03/23 09:37 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
There was a member here that made (and sold here) a dual speaker mount that is a replacement for the stock oval.
Basically an aluminum plate and two 3" round element holes.Once speakers were fitted they could be wired for either mono or stereo (with a modified stock radio) for stereo.
Re: Best dash speaker for b body [Re: srt] #3148513
06/03/23 11:21 PM
06/03/23 11:21 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Most 60/70 Mopars used a a 4x10" oval speaker up front...
EZ to make a drop-in replacement by taking (2) 3.5" speakers and mounting them on a an adapter plate made out of thin aluminum like a cookie sheet. By making template and cutting round holes for mounting the speakers and creating extended end ears for mounting to studs under the dash. Next is how to connect up depending upon what head unit U have..
1. If using an mono AM Mopar OE head unit, the (2) speakers should be wired in series for an 8 Ohm load(3.2 Ohms + 3.2 Ohms).
2. If using an aftermarket stereo head unit the (2) speakers should be wired (1) to the left front output(3.2 Ohms) and (1) to the right front output(3.2 Ohms).
Just my $0.02... wink
Re: Best dash speaker for b body [Re: Sinitro] #3148523
06/04/23 12:50 AM
06/04/23 12:50 AM
Sounds like I should stick with a stocker. I had an am with a convertor setup in a 69 rr that did well enough for what I want. I know that one wasn’t upgraded internally. Just wanted to get the best I could for a fresh start on this car. I want this summer to be the last time crawling under the dash.
Re: Best dash speaker for b body [Re: Pacnorthcuda] #3148588
06/04/23 01:09 PM
06/04/23 01:09 PM
moparx Offline
moparx  Offline
beer
thank you sir ! up bow
i bookmarked that for future use.
beer
Re: Best dash speaker for b body [Re: moparx] #3148598
06/04/23 01:43 PM
06/04/23 01:43 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
beer
beer
Absolutely a great place and a great staff still alive and well !!
Re: Best dash speaker for b body [Re: srt] #3148648
06/04/23 05:16 PM
06/04/23 05:16 PM
Unfortunately back in New York
N
Nukechargerboy Offline
N
Just did this last summer. I couldn't tell you who I bought the bracket from. It was someone on here. I put JL speakers in with a retro radio. 5x7 in the back, sounds better than the fuel pump.
Re: Best dash speaker for b body [Re: srt] #3148797
06/05/23 09:55 AM
06/05/23 09:55 AM
N
NITROUSN Offline
NITROUSN  Offline
N
I have one that he made for my 69 B-body if someone wants it.
Re: Best dash speaker for b body [Re: NITROUSN] #3149407
06/07/23 02:28 PM
06/07/23 02:28 PM
I went with the sm electotech one. Mine ended up being a low ohm one that blew the transistor.
Re: Best dash speaker for b body [Re: SomeCarGuy] #3149503
06/07/23 07:45 PM
06/07/23 07:45 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
There are places that can rebuild your orig. speaker.
Re: Best dash speaker for b body [Re: 71GTX471] #3149731
06/08/23 02:41 PM
06/08/23 02:41 PM
moparx Offline
moparx  Offline
what ohm speaker were the originals, and what happens to the radio if one just sticks in "any old speaker" that fits, of a different ohm impedance ? [i think that's the correct term to use]
beer
Re: Best dash speaker for b body [Re: moparx] #3149739
06/08/23 02:57 PM
06/08/23 02:57 PM
I "think" the originals pre 1974 factory single speakers where 4 ohms, maybe 8 ohms. confused
As far as ohm rating the smaller, lower, the numbers the less resistance. I'm not sure about how that affects the wattage needed to drive them confused shruggy
I'm wondering if the stock AM and AM/FM/ and AM/FM tape player radios had different wattage output for multiple stock speakers work confused
Re: Best dash speaker for b body [Re: moparx] #3149795
06/08/23 06:24 PM
06/08/23 06:24 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
beer
In the 50/60/70s most automotive OE speakers were 8 Ohm...
In the 80/90s, as the OE head units increased in power by adding more channels and higher power (transistor-based) output stages, the speaker impedance spec dropped to 4 Ohms..
Today most replacement automotive speakers are 4 Ohms, some like the Infinity reference are 2.8 Ohms.
My experience for most installs in our vintage Mopars, the biggest risk is putting a 4 Ohm speaker on an older OE head unit that was designed for 8 Ohms.
Note that a 4 Ohm speaker requires 2X the current of an 8 Ohm speaker, and this additional current requirement frequently will burn out the amplifier output stage in an older Mopar vintage head unit.
Final note, later aftermarket head units have higher current capability and also typically will have more built-in protection circuits for shorts and/or low ohm speaker loads.
